Roundnose D Series Conversion
26 replies to this topic
#16 lawrie124
lawrie124
  • 1,710 posts
Posted 22 January 2016 - 05:26 AM
I thought I recognised that car.
It was my lads project!
http://www.theminifo...-rebuild/page-3
#17 Simples
Simples
  • 106 posts
Posted 23 January 2016 - 10:26 PM
Yeah that's the one
#18 mini_matt_106
mini_matt_106
  • 591 posts
Posted 02 March 2016 - 03:36 PM
Just bought a civic daily 1.5 vtec sohc great Eco plus a bit of power. Would go well in a mini!
#19 Simples
Simples
  • 106 posts
Posted 28 June 2016 - 09:35 PM
Been a while, just got back into this, welded in the fuel filler blanking plate
Cut some more holes
Attached some fresh metal and attached the sill
Also started on the boot floor
Edited by Simples, 28 June 2016 - 09:37 PM.
#20 Simples
Simples
  • 106 posts
Posted 14 July 2016 - 07:56 PM
Got some colour on, subtle enough
Edited by Simples, 14 July 2016 - 08:14 PM.
#21 Simples
Simples
  • 106 posts
Posted 03 August 2016 - 10:13 PM
Shell's the right way up (first time in a year or so)
Started on the rear panel repair and found a lot of filler
I was waiting to find a load of crumpled metal, but it was just to cover the previous substandard repair
The boot corners
How it's left for now
#22 Shukran
Shukran
  • 129 posts
Posted 08 January 2017 - 03:03 PM
And then?
#23 dunejunkie
dunejunkie
  • 18 posts
Posted 02 February 2017 - 06:24 PM
In regards to the subframe, a company called minitech, out of Georgia, makes a d series subframe. I have one in my roundnose and it works great. Takes a little bit of fiddling in order to get the suspension right, but overall a great "drop in" solution. Comes with the frame, coil over mounts, custom axels, and a few other conversion bits. Here is their website: http://www.superfastminis.com/
There are also loads of people who have modified the original subframe, which allows you to retain the original mini suspension, rather than going to the full custom adjustable suspension with coil overs. Also, if you have the skills, building your own subframe could save you a wad of cash.
Edited by dunejunkie, 02 February 2017 - 06:28 PM.
#24 Simples
Simples
  • 106 posts
Posted 02 February 2017 - 09:57 PM
Yeah, going to make my own subframe. Will get back on it shortly, not having a garage makes doing anything over the winter a struggle, I want to have it pretty much done before the end of the year
#25 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 01:48 AM
37225551872_5668ff517f.jpgmini by joaquinn lopez, on Flickr
36585072173_faf0e5c5e8.jpgitb mini by joaquinn lopez, on Flickr
this is on a homemade subframe
#26 Simples
Simples
  • 106 posts
Posted 02 October 2017 - 10:17 AM
This is well overdue an update...keep getting distracted by other things O_O
Been collecting parts, even if they're not needed for a while
Brought some trunnions and started to converted the rear subframe to a beam set up
Seam welded the rear tubs and will strengthen the top mounts too
Started on the rotten boot floor to rear panel
Saw a few bits round the rear subframe mounts so it ended up like this
Also welded some reinforcement into the heelboard for the rear beam to bolt to. Hopefully be a bit more consistent with progress from now on  :lol:
Edited by Simples, 02 October 2017 - 06:42 PM.
#27 mini_matt_106
mini_matt_106
  • 591 posts
Posted 03 October 2017 - 09:13 AM
Great stuff, keep it up!
My civic d15 is now on 118k miles and still amazingly reliable
