Mk3 Door Skins
rust repair paint
5 replies to this topic
#1 plus1803
plus1803
    Just On Tickover
  • 5 posts
Posted 02 September 2015 - 03:20 PM
Hi all,
Having a bit of a dilemma with a rotten left-hand door. To date I've removed and patched the rust along the base of the frame and small sections in the skin itself. This was done just as an exercise to see if it could be salvaged to last a few more years (student budget life!). As a result the skin inevitably warped and many large layers of filler applied but it hasn't quite achieved the curved look.
Do I bite the bullet and buy a new door skin?
If so are they difficult to fit? I've read up on curving, sealing and welding the edges of a new skin but just wondered if it will convex/concave and therefore need filler applied?
Any wisdom much appreciated!
Will
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 02 September 2015 - 05:12 PM
I reskinned my mk1 doors using magnum panels, not difficult but you will have to repair the frame if needed and it's easier if you have a door skinning tool, then it will need sealing and painting, may be easier to find a better door and swap it over. Depends on you confidence and what tools available.
#3 plus1803
plus1803
    Just On Tickover
  • 5 posts
Posted 02 September 2015 - 05:28 PM
I'm confident with fixing the new skin down to the frame it's just whether or not causing the skin to bow is easily done?
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 02 September 2015 - 05:53 PM
I had no issues with folding skin over lip of frame. The only problems I had was the mods I had to do to the skin to fit the handles as holes were incorrect shape, then I had to extend the edges in places to get it to be a good match and fit as per the original. Maybe that was magnum skins but I have heard people have issues with heritage ones as well.
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 02 September 2015 - 06:03 PM
Use a Heritage skin as these are generally better than magnum. Buy the lower repair section for the door which is curved although some are more curved than others. I have had to section a couple to remove some of the curve.
#6 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 September 2015 - 08:49 PM
When i was taught to skin a door, i was told if you do it right, no filler is needed. if you find yourself using filler, you have done it wrong.
When folding the skin over, you need to first lay the frame onto the skin so the door is skin side down. It needs to be well supported so it's not rocking around all over the place as you fold.
I always fold just the corners first to hold the skin in place and then try the door on the car. if the skin is in the wrong place, it can easily be moved.
I would advise not using any 'door skinning' tools. They don't make a better or quicker job in my opinion. best bet is a hammer and dolly. You want a dolly with a nice weight to hold against the outside of the skin where you are folding. you need to hold it with enough pressure to support the skin but not to bounce around while you are hammering.
use a bumping panel hammer and carefully make your way round the skin knocking the edge over a 1/3 of the way, then go round again another 1/3 and then a final run to fold it up tight.
If done well and with patience, you will have a nice smooth ripple free finish that is ready to paint.
You could always add a bead of sikaflex around the edge of the skin prior to dropping the frame on and as you hammer the edge over, it will squeeze out and create a decent seal all the way round.
You can also use one of those skinning tools to go round once after the edges are folded just to tighten the folds up nicely but be careful to avoid rippling.
it's also a good idea to counter sink the water drain holes in the frame before fitting the skin to help with drainage.
Ben
Also tagged with one or more of these keywords: rust repair, paint
