Mini Wheel Colour Not Old English White
paint
3 replies to this topic
#1 Oli_Bell
Oli_Bell
  • 17 posts
Posted 26 June 2016 - 06:44 PM
Hi Guys,
I bought a set of copper reverse rims for my mini in Old english white from John Brown wheels.
http://www.johnbrown...e-with-Cap.html
When they came they weren't the cream colour but a bright white. The OEW looks so much better. Whats the deal. Is this normal that companies advertise as OEW but its actually not? Anyone had this before?
Should JBW replace them for me?
Oli.
#2 Hedgey
Hedgey
  • 179 posts
Posted 07 July 2016 - 01:09 PM
Do you have a pic of the actual white they came in?
#3 Ethel
  • 26,786 posts
Posted 07 July 2016 - 02:05 PM
They are obliged to replace or refund if they're not as described.
#4 absx2
absx2
  • 960 posts
Posted 08 July 2016 - 08:19 AM
I purchased a few from Minisport a while back but I would imagine they all come from the same manufacturer.
I ended up with three different shades and only one out of twelve wheels was actually running true, one was 6mm out of true !!!!!
I spun them up on a hub rather than a balancer and Minisport kept replacing them until I ended up with the best but not perfect lot.
I would advise you to fit each rim to a hub and give them a spin. Use bits of yogurt pot as washers so you don`t damage the finish.
If all is well you can etch prime and and spray the wheels in the shade you want as the factory finish is not durable and you will be doing it again anyway.
Also tagged with one or more of these keywords: paint
