No im having trouble mounting the radius arms to the subframe its selfIs this the same problem you are having?
http://www.theminifo...mounting-holes/
#16
Posted 20 December 2016 - 11:49 AM
#17
Posted 20 December 2016 - 11:51 AM
Chris -
I'm assuming we're talking these:
https://www.minispar...=170/21A197.jpg
If so they should definitely have come with your new frame - if it was a new one from factor / supplier - get it back to them and get a replacement one with the brackets.... if not - as Nick suggests "fun" will ensue......
You can get adjustable brackets for a finessed set up that MAY do the trick - but if you've alignment issues as is then pain and angst to follow! :-(
#18
Posted 20 December 2016 - 11:54 AM
Sadly it was second hand and no brackets these adjustable ones can you position the holes and adjust from there? ThanksChris -
#19
Posted 20 December 2016 - 11:55 AM
Whoops crossed post.... these are the brackets that MAY solve the issue....
https://www.minispar...assic/MS70.aspx
otherwise its lots of filing / fettling - if you're lucky!!!
(Don't suppose it'd be worth chasing down whoever you bought the frame from to see if they've still got the originals?????)
#20
Posted 20 December 2016 - 11:59 AM
ll do a trip to mini spares and ask people there with the subframe and look into those brackets thanks for the help man!Whoops crossed post.... these are the brackets that MAY solve the issue....
Edited by ChrisTierney, 20 December 2016 - 12:03 PM.
#21
Posted 20 December 2016 - 12:37 PM
Here's hoping - those brackets are for a generic "fit" - i.e not specified for gen / non gen frames so with a bit of luck will have enough tolerance to sort you out - with the added bonus of adjustability for decent alignment - some non oe frames even when supplied with bracketry give shocking alignment........ all fixable but a pain nonetheless....
Just a potential note of caution - others have reported problems with adjustables from some suppliers necessitating from memory - welding them up when aligned perfectly I've never had issue with anything from minispares though...
For ref - all rover frames even to the end of production were stamped "MOWOG" so easily determined (not sure about heritage ones though....)
#22
Posted 20 December 2016 - 05:07 PM
Awesome man thanks so much for your help appreciate it!Here's hoping - those brackets are for a generic "fit" - i.e not specified for gen / non gen frames so with a bit of luck will have enough tolerance to sort you out - with the added bonus of adjustability for decent alignment - some non oe frames even when supplied with bracketry give shocking alignment........ all fixable but a pain nonetheless....
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
