I Want Sportspack Arches But Don't Want New Holes..
detailing
12 replies to this topic
#1 Glenny1481
Glenny1481
  • 41 posts
Posted 21 April 2017 - 05:54 PM
I know that there's probably no way this is actually possible to the point where it actually works but is there any way I can fit sportspack arches without drilling new holes? I have the standard black plastic ones and my car is completely standard and never had welding plus my dad wouldn't let me drill new holes but I love the look of the wide sportspack. So any suggestions or ideas are welcome cause I don't have many that I can think of that will actually work.
Glen
#2 Midas Mk1
Midas Mk1
  • 5,852 posts
  • Local Club: S.U.N.M.C
Posted 21 April 2017 - 06:04 PM
Man up and drill the holes, or don't run sportspack arches..
Your car, your choice.
#3 Richie83
Richie83
  • 1,495 posts
Posted 21 April 2017 - 06:51 PM
There's no way around it. Also be aware they are huge and come quite a way up the wing. Your wheels might not fill the arches (what wheels do you have) and if you get bigger wheels the front wings will need to be cut to accommodate them. All in all it's not straight forward; don't buy the rubber type either because many have found them to be useless.
#4 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 21 April 2017 - 08:28 PM
Yep, its not the holes drilled you want to worry about, its cutting up most your wings to do it that'd the *******.
#5 tiger99
tiger99
  • 8,584 posts
Posted 21 April 2017 - 08:50 PM
Don't forget welding in the new arch edge stiffener, item 11 here:
http://www.somerford...&id=6&chapter=1
#6 timmy850
timmy850
  • 3,603 posts
  • Local Club: MITG
Posted 21 April 2017 - 09:34 PM
There is a recent post here where sportspack arches are fitted. You can see how much metal needs to be cut off..
http://www.theminifo...14#entry3452431
#7 Glenny1481
Glenny1481
  • 41 posts
Posted 21 April 2017 - 09:36 PM
Yeah this is what I expected hahah. Just thought I'd ask cause hey do look good but not worth chopping my car to bits for. I've heard that group 2 arches fit in the standard holes? If anyone can confirm what arches actually do fit in the standard holes that would be great as one of mine came flying off a couple of days ago thanks to a nice big pot hole that shattered it
#8 MacGyver
MacGyver
  • 1,028 posts
Posted 22 April 2017 - 07:58 AM
Groupe2 and groupe2 race fit in the special arch holes if that's what you want to know... 😀
E- What wheels are you trying to cover?
Edited by MacGyver, 22 April 2017 - 07:59 AM.
#9 mab01uk
mab01uk
  • 13,068 posts
Posted 22 April 2017 - 09:37 AM
Wood and Picket arches fit without drilling holes in the bodywork panels (you drill the hidden fixing holes from below into the arch flange/lip) and they usually cover existing plastic wheel arch holes. Also no need to cut the front wings if you run with the standard ride height and width factory/option 10/12" alloy wheels (not the 13" Sportpack alloys).
#10 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 22 April 2017 - 09:44 AM
If your going for arches then you will want wheels to suit. Before you make any decisions make sure you understand the side efects of the bigger wheels. I think there is a good section on keith calvers site explaining things.
at the end of the day it may not matter to you, thats fine, but make sure you have all the facts first. :-)
#11 Mervyn
Mervyn
  • 256 posts
Posted 22 April 2017 - 08:36 PM
Give it a few years and you'll be glad you didn't chop it about for silly arches
I ruined many a mini back in the day, looking back
Merv
#12 Glenny1481
Glenny1481
  • 41 posts
Posted 23 April 2017 - 08:13 AM
I have the standard rover ones with an offset of 35 and are either 4.5 or 5 inch wide I'm not entirely sure but I really don't like them, the ones I want are 12x6 with and offset of -7 so they stick out a fair amount further so I'll obviously need new arches just wasn't sure which ones. Thanks for the help though I'll take a look at them
#13 SuperDeLuxeNick
SuperDeLuxeNick
  • 625 posts
  • Local Club: West Country Minis
Posted 23 April 2017 - 09:43 AM
group 2 narrow from Huddersfield Spares or similar fit direct into exsisting holes and are ideal for 10x6 wheels
(in most cases) different brakes etc can cause wheels to stick out more etc
I have drums front and rear - lowered about 15mm all round - 10x6 UltraLite wheels - group 2 narrow arches and they sit perfect and no cutting and no rubbing at all.
You need to spend an hour or so reading about Wheel Offset and how it works, as well as deciding what sort of look you want to achieve.
Also tagged with one or more of these keywords: detailing
