Relay Pack Clicking On Off ?
electrical
11 replies to this topic
#1 paulj63
paulj63
  • 10 posts
Posted 24 May 2019 - 01:58 PM
Hi All
Hope you can help
I have an issue with the relay pack clicking on and off resulting in fuel pump not kicking in.
If i hold the relay pack switch down with finger the pump kicks in,
bought a brand new relay pack from minispares and still the same problem so its not the relay pack
tried disconnecting battery to re set computer
Could it be the fuel purge valve next to the wiper motor ?
before i go buying loads of parts to try has anybody else had the issue
car is . 1993 rover mini SPI
Fuel pump is fine
relay pack is fine
all fuses are fine
been looking at this for the last 3 weeks
cheers
Paul (Flintshire)
#2 hunterg30
hunterg30
  • 349 posts
Posted 24 May 2019 - 03:01 PM
You only normally hear the fuel pump clicking when you first turn ignition on. Can't say I have heard it after. Is it the black relay pack you have checked or the yellow one next to the fuel cut off switch?
Edited by hunterg30, 24 May 2019 - 03:07 PM.
#3 paulj63
paulj63
  • 10 posts
Posted 24 May 2019 - 04:20 PM
Hi
Its not the fuel pump clicking its the relay pack (black)
Fuel pump works fine when the clicking stops from the relay pack (black)
the relay pack is premaritally clicking away, its a brand new one and does the same as the old one did.
weird this one ???
cheers
#4 hunterg30
hunterg30
  • 349 posts
Posted 24 May 2019 - 07:58 PM
Sprocket has wrote on here the functions of the relays .Search for Spi Relay Pack Functionality. This should help you
#5 paulj63
paulj63
  • 10 posts
Posted 25 May 2019 - 01:50 PM
Arhhh heads gone !!!!
#6 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 25 May 2019 - 02:16 PM
I would check for a bad connection on the main feeds. battery earth and positive ,and solinoid connections.
When the relays close they put a load on a bad connection causing it to fail and the relay drop out.
How bad a connection is is usually proportional to the load you try and put through it. It may be able to carry enough power for the relay coil but not the load its switching.
#7 paulj63
paulj63
  • 10 posts
Posted 25 May 2019 - 08:14 PM
Hi Mate
Yes makes sense about the lead connections,
i will have a good look tomorrow.
just got to remove the hammer from the wing first !!!!!  lol
cheers
paul
#8 paulj63
paulj63
  • 10 posts
Posted 30 May 2019 - 12:24 PM
Hi
Checked all earth connections everywhere all secure,
just ordered a new purge fuel valve solenoid to try
will update when arrives
cheers
Paul
ps, got the hammer out !!
#9 paulj63
paulj63
  • 10 posts
Posted 08 June 2019 - 08:16 PM
Well new purge valve fitted same problem,
back to the drawing board
#10 paulj63
paulj63
  • 10 posts
Posted 14 June 2019 - 05:41 PM
Update time . still the same !!
#11 paulj63
paulj63
  • 10 posts
Posted 27 July 2019 - 02:46 PM
Still not working !!
#12 FlyingScot
FlyingScot
  • 2,676 posts
Posted 28 July 2019 - 10:33 AM
The MFU aka relay pack is described in the pinned thread http://www.theminifo...-functionality/
The relay for the fuel pump is controlled by the ECU, so check wiring continuity, earths and crank sensor connection. Your getting an intermittent drop in the earth causing the relay to drop out.
FS
