A+ Dizzy In An A Block
9 replies to this topic
#1 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 07 October 2019 - 10:29 AM
Hello,
I am building up a 1275 with a A series block but have a new A+ dizzy.  Can someone confirm what parts I need to marry the two together?  I have an A+ drive and an A series dizzy mount but the A series clamp will not fit on the A+ locking collar. So do I need to keep the A series dizzy mount but use the A+ locking fork?  Are the lengths of the A+ dizzy and A+ drive compatible with an A series mount?
Thanks,
Paul
#2 Honda-Mini
Honda-Mini
  • 128 posts
  • Local Club: Cornish mini club
Posted 07 October 2019 - 10:37 AM
the drives on the end are thicker on the A+ so at the least you'll need to either change the drive in the block or the drive peg on the shaft. after that theres the issue of the clamp, im not sure if the fork that hold the A+ fits into the hole that holds the A distributor, or if you left that out if the hole would be too large IYSWIM
#3 floormanager
floormanager
  • 804 posts
Posted 07 October 2019 - 10:57 AM
Thanks.  I think I've answered my own question.  The A+ Drive and dizzy are too short to connect, when using the A series mount.  The hole in the block is too big in an A series to fit the A+ drive.  Guess I need a new Dizzy :ohno:
#4 nicklouse
  • 19,067 posts
Posted 07 October 2019 - 11:12 AM
they can be made to fit.
Moke spider has mentioned how somewhere
#5 floormanager
floormanager
  • 804 posts
Posted 07 October 2019 - 12:32 PM
Where's Mr Moke when i need him!! Asleep probably ;D
#6 grizzler73
grizzler73
  • 300 posts
Posted 07 October 2019 - 01:36 PM
I had the same issue and looked into it, you can change over the drive at the base of the dizzy but its a bit of a faff, also you need to modify an A+ clamping bracket as they are different. I'm going to get one of these instead!
Much easier!
#7 Honda-Mini
Honda-Mini
  • 128 posts
Posted 07 October 2019 - 01:46 PM
Much easier!
but these dizzys are A+ only... the OP has one of those to fit to an A block?
#8 grizzler73
grizzler73
  • 300 posts
Posted 07 October 2019 - 02:13 PM
Ooops!  There is a Pre A + one also
http://www.minispare...px|Back to shop
#9 floormanager
floormanager
  • 804 posts
Posted 07 October 2019 - 03:46 PM
Thanks. I've found the link to mod the A+ dizzy
http://www.theminifo...k/?fromsearch=1
#10 Spider
  • 15,880 posts
Posted 07 October 2019 - 04:44 PM
I've done this by swapping the Drive Dog on the distributors, and otherwise using all the A+ parts for fitting, however, this only works with the 45D4 and later Distributors. The 23 and 25 types are 'too bulky' where the fork needs to go in.
On the sleeve / collar that fits in the block, a tab needs to be welded on and a thread tapped in to that to mount the fork to. There are some photos on the forum of this.
Yes !
