Rear Subframe Questions
suspension
7 replies to this topic
#1 Manx lee
Manx lee
  • 10 posts
Posted 09 January 2020 - 06:09 PM
Can you replace the rear subframe mount pins the ones that attach to the boot floor as mine the threads have stripped
#2 jeffster06
jeffster06
  • 113 posts
Posted 09 January 2020 - 07:47 PM
Someone who knows more than me might come along but on my 91 cooper those mounts had bolts that came through on the boot side, they came in my new hardware kit so not sure why yours has studs, unless someone put something over the heads on the boot floor.
#3 KTS
KTS
  • 2,490 posts
Posted 09 January 2020 - 07:54 PM
The rear mount brackets bolt up through the boot floor, but it's the thread on the pin that holds the bracket to the subframe that's stripped by the sounds of it
It's not easy to replace the pins, but there's at least one post on here somewhere describing how it can be done
#4 Manx lee
Manx lee
  • 10 posts
Posted 10 January 2020 - 07:27 AM
Kts yeah that’s the ones I was trying to describe
#5 nicklouse
  • 19,058 posts
Posted 10 January 2020 - 08:14 AM
not a serviceable part.
subframe needs to come off to weld in a new pin or replace subframe.
#6 Manx lee
Manx lee
  • 10 posts
Posted 10 January 2020 - 09:45 AM
Subframe is out and fully stripped was wondering weather I can buy that pin so I can cut out and replace
#7 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 10 January 2020 - 09:58 AM
Maybe re cut the thread smaller and use a smaller nut and a big washer ?
#8 GraemeC
GraemeC
  • 7,472 posts
Posted 10 January 2020 - 11:23 AM
New pins not available, however it can be repaired with some care, patience and skill.
There's a post on the board somewhere where this has been done.
Also tagged with one or more of these keywords: suspension
