Posted 01 February 2020 - 04:33 PM
I have put in a new heater matrix and a new valve and it doesn’t appear to have helped much however a new radiator has also been recently installed so not sure if this would effect how hot the heater gets.
Any help is much appreciated thanks
Posted 01 February 2020 - 04:45 PM
Valve on the head or the remote type?
Easiest thing to check is if the thermostat is working - does the top hose get warm as soon as the temp gauge moves?
Posted 01 February 2020 - 05:22 PM
Could be airlock , and most minis need more than idle revs to pump water through the heater
Posted 01 February 2020 - 05:53 PM
Check the hoses to and from the heater, the one ‘to’ will warm soonest. Disconnect the 'from' and backfill the pipe with a watering can, or similar. That should solve an airlock.
Edited by Quinlan minor, 02 February 2020 - 12:13 PM.
Posted 02 February 2020 - 10:24 AM
Check that the thermostat is working correctly.
Posted 02 February 2020 - 11:36 AM
Posted 04 February 2020 - 01:59 PM
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
