I have a very nasty problem, and would like to ask Your help.
I have just rebuilt a 1275GT engine, and it is burning a LOT of oil. I will post pictures to let You see the depht of the problem.
The cranc was cracked between the cyl no2 and 3, thus it was velded and the bores sleeved back to std size. Pison-bore clearance: 0.06mms, ring clearance in grooves 0.05-0.06mms, ring gaps comp: 0.3, oil1: 0.25, oil2: 0.35. Cranc and head skimmed. Head rebuilt using brand new followers, valves. Oil seals on inlets.
Oil presure perfect hot and cold, at idle or reved. Engine is running smooth and fine. Willing to rev. No oil in water or water in oil. Compression tester shows 15-16 psi.
Crancase vent on clutch cover and valve cover, but not connected to inlet manifold. No gas on valve cover, some at clutch housing vent.
Smoking starts HOT. When cold it is not smoking.
Engine ran about 2-3 hours.
Tried yet without success:
- replacing head
- replacing oil (different types, brands 20/50-15/40)
- bypassing mechanic fuel pump
- using different head gasket
Please help a suffering mini nut...
