As many of you will know, I am making a brand new custom loom for TMF long time member Teapot's pride and joy, Huey. After many delays and a few setbacks, work hassles and brain ache, I am now close to finishing. Designs are done, a secret loom building device is in play, Teapot has measured up a template for me in Huey to confirm most dimensions and I am busy measuring, cutting, crimping, soldering and heatshrinking to put it all together.
I am asking you guys to help me get Teapot back on this forum as he has taken a break until Huey's loom is finished, so PLEASE help me with what may be simple confirmations or even daft questions so I can make sure when this gets sent to Teapot-land it fits Huey snugly and works first time! I know you won't let me down
So - the basic design is to use newer thinwall cable for it's higher ampage rating giving a lighter loom, but to offest that by running more wire making the design simpler to understand later in life. I am using an 8-way fusebox with an approximate 4/4 split in terms of permanent live vs switched live. I plan to run 11 amp wire from the starter solenoid to each fuse with 2 wires per ring terminal at the solenoid, meaning 2 ring terminals for each of permanent and switched sources.
The first question (of many, possibly) might be a silly one ...
On the solenoid, am I right in thinking that the post with the added spade terminals is the switched live, and the post without is the battery connection? Also, does anyone know the diameter of ring terminal needed to connect onto the posts?
Thanks!
*wanders off to cut and crimp the brakelights*
