Best Performance Coil And Distributor
39 replies to this topic
#31 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 19 November 2008 - 10:41 PM
Kit 1 wheel does not need any work by yourself as it bolt to the existing holes that are located on some pulleys. All you have to do is set your engine at TDC, remove the bottom pulley and fit the kit. The bolt holes that are in the pulley and trigger wheel then line up with TDC. So you can still set your timing and run your car without fitting the Megajolt.
Thanks for that, just one other thing:
Just to make absolutly sure, is it perfectly and works perfectly, to use a megajolt set up on a carb running mini? Just a little doubt I have in the back of my mind.
#32 Steve D
Steve D
  • 128 posts
Posted 19 November 2008 - 10:52 PM
Yes mate it is perfectly and works perfectly, to use a megajolt set up on a car running on a carb set up. All a megajolt is a set up which lets you map your advance. So your timing is correct throughtout your rev band.
#33 cng1
cng1
  • 10 posts
Posted 19 November 2008 - 11:14 PM
Hmm. So kit 1 is only effectively of use on the 10% (based on the stash of pulleys that I have here) that have the bolt holes. What do you suggest people do with the "crud guard" fitted to the rear of most pulleys? Hammer it off with a chisel, grind the welds off or do you have some other plan?
Also on kit 2 are you modifying a standard hamonic damper pulley to have the teeth in or are you making a new one from scratch with a new rubber insert?
#34 Steve D
Steve D
  • 128 posts
Posted 19 November 2008 - 11:19 PM
Use kit 2 which is a whole new pulley.
#35 cng1
cng1
  • 10 posts
Posted 19 November 2008 - 11:26 PM
A whole new pulley complete with harmonic damper or a solid, undamped pulley?
#36 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 20 November 2008 - 05:43 PM
Ok thanks, megajolt it is then.
#37 cng1
cng1
  • 10 posts
Posted 20 November 2008 - 11:23 PM
For people who have the common non-bolted pulley and want to retain the harmonic damper this looks like it may be an option:
http://trigger-wheel.../en-uk/d30.html
#38 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 21 November 2008 - 09:49 AM
Thats look good, nice idea.
#39 rozzer1275
rozzer1275
  • 439 posts
  • Local Club: ah
Posted 21 November 2008 - 01:15 PM
home bodged pully and trigger wheel
#40 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 21 November 2008 - 03:25 PM
Looks good, how did you make the trigger wheel?
