Manifold Heat Wrap
#16
Posted 06 January 2009 - 10:44 PM
#17
Posted 06 January 2009 - 10:48 PM
#18
Posted 06 January 2009 - 11:04 PM
#19
Posted 06 January 2009 - 11:07 PM
thats exactly what happend to mine and it cracked on the welds ,then set my engine bay on fire !! lol
ive got some grate pics ill post up later
Edited by fatmini, 06 January 2009 - 11:09 PM.
#20
Posted 06 January 2009 - 11:09 PM
dam, thats some heat
aye - not just on one car, or one 'batch' of manifold... a regular thing...
#21
Posted 06 January 2009 - 11:11 PM
#22
Posted 07 January 2009 - 10:31 AM
Quote " the welds seem to be fine... but the tubework just collapses.. like a bog toll tube.. can crush it in you hands... " Quote
Wow scary! Show us some pics!
I have a Maniflow LCB so for now I think I'll try the heat shield idea. I have some stuff that plumbers use when welding to protect whatever's behind the pipes, so I'll fashion something out of that.
#23
Posted 07 January 2009 - 04:21 PM
Posted 07 January 2009 - 05:51 PM
I expect it occurs at a slower rate on unwrapped manifolds, so the only real cure is to ceramic coat the manifolds to provide both insulation, and protection. If this is the case, then it makes for a pretty poor case in favour of using thermotec type wrap on anything other than a racing car, and even then the medium term cost analysis will probably favour the coating process.
Hope this helps
Paul
#25
Posted 07 January 2009 - 10:11 PM
Would the ceramic be applied to internal and external diameters?
Also I remember a time when stainless steel manifolds where sold the mild steel one is favoured because it isn’t as brittle and is more forgiving of the forward and backwards movement of most a series engines
Can you still by SS manifolds and if so does any one know who uses them and what the life expectancy of them are/is
#26
Posted 07 January 2009 - 10:35 PM
The main reason for wanting it is to keep the heat away from the feed from petrol pump to carb
That section of pipe should always be solid metal, preferably steel as original. You haven't replaced it with rubber have you?
Edited by Dan, 07 January 2009 - 10:37 PM.
#27
Posted 07 January 2009 - 10:36 PM
Hmm some mixed views there. I'm a little bit worried about it 'corroding' and 'distorting' my manifold. The main reason for wanting it is to keep the heat away from the feed from petrol pump to carb and also because I thought it was good for performance to keep the heat it.
Did you consider moving the fuel pipe, you can rotate the pump outlet, then take the pipe almost straight up, onto the bulkhead, accross behind the carb, and into the carb?
Dave
#28
Posted 07 January 2009 - 11:05 PM
some pics
yep thats what i had, exactly the same. Cracked at heat effected zone of the weld.
also just read what dan said on mine the sound insulation has melted round the exhaust tunnel by the gear stick.
Edited by rozzer1275, 07 January 2009 - 11:06 PM.
#29
Posted 07 January 2009 - 11:13 PM
#30
Posted 08 January 2009 - 12:06 AM
If you choose to lag a steel pipe then you can give the lagging a liberal coating of high temp paint and that helps to prevent the lagging taking up any water. It also insulates the pipe even more I would have thought. Personally the only lagging I have used is on my fmic pipes post cooler where they run through the bay! Again not my Mini which boasts no lagging but does have a heat shield between the carb and the soot pipe.
My fuel pipe is also routed as per Dave's post using high quality fuel line!
Edited by Strontium Dog, 08 January 2009 - 12:10 AM.
