Probably Bought The Wrong Wheels
34 replies to this topic
#16 stussymini
stussymini
  • 37 posts
Posted 18 January 2009 - 08:16 PM
ok i run out and check at the back of them...back of what the tyre or the rim?
#17 Bungle
Bungle
    Original Spamster
  • 28,971 posts
they sound like standard 4.5x12 minilights with maybe 165 tyres
#18 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 18 January 2009 - 08:20 PM
i agree,standard early cooper alloys
#19 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 18 January 2009 - 08:22 PM
yes, i agree and a 145 tyre on the "spare"
the size should be stamped on the wheel, in one of the four "pockets" in the rear of the hub, i think. unfortunately i lost my images when i had to re-boot my PC.
if they are exactly the same as the ones in my topic, then they will fit. read the topic fully and you will know all you need to know :proud:
#20 stussymini
stussymini
  • 37 posts
Posted 18 January 2009 - 08:30 PM
hey guys i think you are all right =] i have read on the inside of the rims and it says 4.5x14 and the tyres are 165..as a matter of fact i have checked the thin one and measured the rim and it seam the same as the others altho it appear thinner....thanks a lot to all of u guys my heart its a peace now and my car will look fantastic...
but do i then need to change tyres or they will be fine...?
also about the refurbishment of the rims...anybody knows what cost am i looking for and who should i look for to do them?
thanks again :proud:
#21 coopermpi
coopermpi
  • 661 posts
  • Local Club: not yet
Posted 18 January 2009 - 08:39 PM
you mean 13??? refurb yourself if they aint too bad, rub them down or nitromors???
#22 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 18 January 2009 - 08:40 PM
tyres should be OK as long as they are in good nick :proud:
i think a wheel refurb is about £30-£40 per wheel but that includes the lot, cant remember the name of the place that most people recommend, but you can google local places =]
#23 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 18 January 2009 - 08:41 PM
14?? what the hell,i thought we were now on about 12s
any chance of some piccys
Edited by the.stroker, 18 January 2009 - 08:42 PM.
#24 stussymini
stussymini
  • 37 posts
Posted 18 January 2009 - 08:45 PM
i meant 12 =] i don't know how to get pics on here...haven't worked that out yet...i'm bordering retard :proud:
#25 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 18 January 2009 - 08:47 PM
dont worry mate.i can just about type!!
Edited by the.stroker, 18 January 2009 - 08:47 PM.
#26 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 18 January 2009 - 08:48 PM
i think i will take them to a tyre shop or kwik fit to see the real measure of them and what they suggest..as really i dont know what size they are..
if they 6wide i think i will re sell them and get some that won't need body mod..
Stay away from Kwik Fit, otherwise they'll either try and jack your car up via the floors or sills etc or try and sell you things you don't need, like new tyres, exhaust, brakes and shock absorbers etc.
:proud:
#27 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 18 January 2009 - 08:50 PM
agreed,try and find a local mini fiendly garage if possible
#28 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Easiest way is to google for 'Photobucket', upload your pictures there and then show them here by cutting and pasting the image code information (IMG CODE), that appears beneath each picture.
#29 stussymini
stussymini
  • 37 posts
Posted 18 January 2009 - 08:56 PM
i should really...but everywhere it seam to be so expensive in london...
if they will fit with the tyres then i'm gonna swap the tyres around and use the bubbled up as a spare for a while...till i have the money for refurbish or the l2b
(if i can get a space inn...)
#30 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 18 January 2009 - 09:03 PM
you will find that most standard cars fitted with alloys are using a steel spare wheel, I'm sure the 13inch minis did and i still haven't found a definitive answer on the 12inch minis, it seems some had a steel and some had an alloy spare ?????
you just use it in the same way you use a space saver spare, to get you home or to the nearest tyre shop.
i think, and i wait to be corrected, the only real thing you can do is match the tyres on each Axel, this means as long as the two fronts match, and the two rears match, it's not so important to match the fronts to the rears etc.
