headlights
Dom
, Mar 11 2004 02:31 PM
23 replies to this topic
Posted 11 March 2004 - 02:31 PM
ive had this problem for a while now but i thought it fixed itself now its back. my headlights have stopped working, you have the switch on headlights and only the side lights work. im not sure what it is but the other day i went over a bump and the headlights started working again. but now theyve stopped.
anyone know why or what causes this?
thanks
thanks
Posted 11 March 2004 - 02:45 PM
probably got a loose bulb there mate!! :wink:
Posted 11 March 2004 - 04:36 PM
Make sure that the connector going to the headlamp is on tight and not worn and wiggling about!
Might have fallen off completely!
Posted 11 March 2004 - 04:43 PM
check the headlight relay.
Posted 16 March 2004 - 11:46 AM
right i checked the lights, the headlamp bulb in the drivers side has stopped working...
is there 3 bulbs in each headlamp?
i have sidelights, headlamp, and full beam. in other cars the full beam works off the headlamp.
anyway ive bought a headlamp bulb so ill fit in when i get the time.
Posted 16 March 2004 - 04:46 PM
it has two bulbs!! the main beam bulbs have dual filment i.e full and dipped headlights, the sidelights are just one small bulb!!
Posted 16 March 2004 - 09:46 PM
thats what i thought but the odd thing is:
1 turn side lights on: they work
2 headlights on: nothing
3 full beam on: side lights, headlights and full beam?!
i dont get it. and before you ask im not counting the spots lighting up.
Posted 16 March 2004 - 10:20 PM
Change the bulb
Posted 16 March 2004 - 10:30 PM
indeed i will mate, i have the bulb bought and ready to fit this weekend
Posted 17 March 2004 - 06:58 PM
don't forget to check the wiring connections, inside the engine bay, there are multi connectors just underneath by the bonnet catch, if one of these has a dodgy connection or is loose, you won't have lights....
take out each cable clean and then refit........
Posted 17 March 2004 - 08:14 PM
I jus had a prob with my headlightes, i had sides, but nothing else. It turned out to be the connection on the starter solonoid was loose!
Posted 17 March 2004 - 08:18 PM
well reminded BMR the power for most things comes from the starter solenoid.... :wales:
Posted 17 March 2004 - 10:06 PM
ill check it out this weekend, maybe take some pics too, the lights are workin again now?! lol
Posted 17 March 2004 - 11:17 PM
indeed, i was driving along in traffic not so long ago and it just stopped dead, no ignition, no hazards, nothing, turned out to just be a bit of dirt on the solenoid, makes all the difference to give it a clean. Also might be worth changing your light rocker switch on the dash, because mine was playing up too, it can work one minute then not the next, might be worth having a look at that.
Tom
Tom
Posted 18 March 2004 - 08:29 AM
yeah my dad thought it might be the switch.
