but as one i am doing now is blow through fitting inter cooler
Care to share any build photos? Do you have a project link????
Posted 26 March 2009 - 03:54 PM
Posted 07 May 2009 - 01:23 PM
I don't know what kind of dump valve you did use. Mine is a forge with a spring in it. The biggest issue is to get the right tension in the valve. You can change the springs and work with shims to setup the correct tension. The dump valve should open when there's a vaccuum in your inlet manifold. When the spring is too strong, the valve doesn't open and your rmp will rise very quick. If the spring is too soft, the valve will not close and you lose air and so you lose power. I found it not very easy to setup, it has to work perfect.
Edited by Prawn, 07 May 2009 - 01:56 PM.
Posted 07 May 2009 - 09:37 PM
Posted 08 May 2009 - 06:39 AM
Posted 08 May 2009 - 08:36 AM
Posted 12 May 2009 - 11:04 AM
How are you sorting the crank pulley for the supercharger?blow through useing turbo carb withm odified plenum and bmw supercharger
Many thanks Stig - just what I imagined (only neater!) is it / was it yours?
no not mine but doing a similar build at the minute but injected
Posted 12 May 2009 - 11:30 AM
Posted 15 May 2009 - 07:53 AM
Posted 12 August 2009 - 03:06 PM
Edited by THE STIG, 12 August 2009 - 03:21 PM.
Posted 12 August 2009 - 03:14 PM
Posted 12 August 2009 - 07:01 PM
Posted 22 November 2012 - 10:48 PM
