It wasn't an easy installation, but it works fabulous!
Mini Asfalt Vreters
Regards,
Remko
Posted 21 March 2009 - 07:14 PM
Posted 21 March 2009 - 07:53 PM
I managed to put a blow-through supercharger system with intercooler in a roundnose mini. And I can change my plugs without removing the supercharger
Mini Asfalt Vreters
Regards,
Remko
Posted 22 March 2009 - 12:52 PM
That's why the other article is in germanmy dutch isn't too good
it's a little difficult to make out in the pictures.
Posted 22 March 2009 - 06:29 PM
blow through useing turbo carb withm odified plenum and bmw supercharger
Posted 22 March 2009 - 06:45 PM
Posted 22 March 2009 - 07:36 PM
I don't think the length of the tubes matter, because the charges is continuous spinning. You only have to wait for the dump valve to close, that valve is very close to the carburettor.Do you get anymore lag with the tubes being longer?
thanks!Hiya remko nice looking van.
I don't know what kind of dump valve you did use. Mine is a forge with a spring in it. The biggest issue is to get the right tension in the valve. You can change the springs and work with shims to setup the correct tension. The dump valve should open when there's a vaccuum in your inlet manifold. When the spring is too strong, the valve doesn't open and your rmp will rise very quick. If the spring is too soft, the valve will not close and you lose air and so you lose power. I found it not very easy to setup, it has to work perfect.did you have a similar problem and if so how did you get round it.
Posted 22 March 2009 - 09:37 PM
Posted 22 March 2009 - 09:45 PM
Posted 22 March 2009 - 10:17 PM
when you compress air it heats up, thats what your cooling by putting an intercooler between the charger and engine
Posted 24 March 2009 - 03:30 PM
Posted 26 March 2009 - 10:14 AM
The other good point is that you wouldnt need to modify the charger internals to take the fuel/air mix, it seems Vmax & johnspeed charge over £100 to do
this.
Posted 26 March 2009 - 10:23 AM
Edited by THE STIG, 26 March 2009 - 10:24 AM.
Posted 26 March 2009 - 10:24 AM
Mr Stig where did you get the photo of the blow through system on the 1st page of the thread?
Posted 26 March 2009 - 10:41 AM
know idea why ?
Edited by BOLDY, 26 March 2009 - 10:42 AM.
