Will give it a try and report back! Unfortunately I have to wait until Monday to get out there
Posted 03 April 2009 - 10:34 AM
Posted 03 April 2009 - 10:42 AM
Edited by Asphalt, 03 April 2009 - 10:43 AM.
Posted 03 April 2009 - 12:33 PM
Posted 03 April 2009 - 05:55 PM
Posted 01 August 2020 - 12:00 PM
Posted 01 August 2020 - 01:04 PM
Posted 01 August 2020 - 02:06 PM
My spacer is a centimetre thick. Just bought it from Minispares for a tenner
Minispares also do a spacer that's 6mm thick.
Posted 01 August 2020 - 07:09 PM
Posted 01 August 2020 - 07:50 PM
Attached is a pic. I think a nut would go behind it and tighten up good enough?
I can't see why not. After assembly and getting it running, check it for leaks.
Posted 01 August 2020 - 08:02 PM
Posted 01 August 2020 - 08:22 PM
Posted 01 August 2020 - 10:52 PM
Posted 02 August 2020 - 07:06 AM
I'd be inclined to just use 2 studs on that. The one opposite the missing one will act like a see saw.
Was the manifold new? That break looks pretty dull & grainy, faulty casting? If you've got the missing bit you should be able to get it tigged back on.
You could try this stuff too, but it'd be hard to get the local heat in to a biggish casting without oxy.
It's got weird properties mind, so have a play with some scrap first. From experience you need the parts solidly clamped or pinned together as is it'll flow into all the metal that's hot enough. The melting point will be lower if you try to rework it and it's a lot tougher to file than plain aluminium.
Posted 03 August 2020 - 08:54 AM
Hi Ethel
I think when i use a nut behind the casting it should be fine. The nut should prevent the see-saw effect.
Yes the manifold was brand new. I've tried to phone maniflow already today but there's no answer- hopefully they'll be able to help.
Posted 03 August 2020 - 10:55 AM
Bank Holiday.
At some point you'll almost certainly want to undo it (It's a Mini) so I'd sooner have a fix that offers the easiest & most varied options for when you're swearing in a lay-by on a soggy winter's night.
