Shaggy
198 replies to this topic
#196 roofless
roofless
    Sticker Pimp
  • 7,216 posts
  • Local Club: central minis
Posted 11 November 2011 - 09:50 PM
Alspeed frame is wider than a standard mini subframe.....this had us guessing for a bit until a quick google search found Kam's build diary on 16v minis ..... All made sense then .....
So rather than bashing bodywork and compromising the positions for the top shock mounts on the front inner wings, we've took a slice or two out of the alspeed frame and welded it back up again. Did the cuts on the fold points of the steel, this allowed us to 'tease' the steel inwards a little when closing up the gaps, and once welded it's now about 4mm narrower each side.
Sorted :thumbsup:
In this pic, you can just about see how the tower tops on the subframe are just ever so slightly wider than the bulkhead cross member..... This obviously stops the inner wings from mating up properly.
#197 samg2007
samg2007
  • 499 posts
Posted 24 January 2014 - 05:59 PM
Did this ever get finished? I need to see that dash finished!
#198 leaky
leaky
  • 6,890 posts
Posted 25 January 2014 - 10:25 AM
Yea what happened with this Martin? Was a sweet project!
#199 roofless
roofless
    Sticker Pimp
  • 7,216 posts
Posted 31 January 2014 - 08:52 AM
its developed into a slightly more complex concept..... that may involve 4WD.....more info soon, concentrating on getting Earl finished first with the 16V 1380 running gear
