2.0 Vauxhall Redtop Engined Mini!
#16
Posted 19 January 2010 - 10:51 AM
#17
Posted 22 January 2010 - 05:13 PM
#18
Posted 23 January 2010 - 12:11 AM
#19
Posted 10 February 2010 - 02:06 AM
What you doing about a subframe john dunno wether we can be of assitance.
Keveric Motorsport
Hi,
Ive looked on your website and it looks great. Ill give you a ring tomorrow.
#20
Posted 10 February 2010 - 03:14 AM
#21
Posted 11 February 2010 - 12:42 PM
John
#22
Posted 14 February 2010 - 09:29 PM
#23
Posted 14 February 2010 - 11:22 PM
Ive managed to get just about everything I need for the conversion(allspeed frame, engine, all linkages, twin webber carbs and sbd inlet manifold, digidash and loaaaads more) of someone selling a job lot so ill have loads of stuff to post over the next weekend as im picking it up this week!
#24
Posted 17 February 2010 - 01:24 AM
Got up to the garage for a bit, managed to paint the inside of the shell
Also started on my bootlid, cutting profiles as this is where the radiator will eventually be mounted
Also I went to pick up all said stuff in my above post and ive just been playing around with a few bits, more pictures to come
Stay tuned, more to come!
#25
Posted 17 February 2010 - 12:20 PM
#26
Posted 23 February 2010 - 10:43 AM
My old one just randomly decided to break the other day, and the conputer whizz at work has branded it a write off:(
#27
Posted 04 March 2010 - 07:18 PM
Just got a quick update of some of the things that have been cracking off in the last week.
Took a picture of what I like to call constructive mess!
Shifted out the spare....
Got the engine and frame in just to mock it up......
Subframe all refurbed and back from the powder coating place! Everything powder coated, Rose jointed bottom arms, uprated hi-lo's etc..
Now it got a bit more technical, Started working on the exhaust. I decided a long time ago that side exit exhausts looked awsome, and that was what it was going to be!
So after a trip to demon tweeks on saturday I ended up with this nice shiny thing. Glad the magpies werent out
The one thing I liked about this back box was the fact that it was reversble and putting it one way made it louder and the other way quieter. You can see how its done inside, one end's internal simple has raised(for want of a better word) flow barriers, and the end is flat.
Then had to calculate the angle of the side panal of the mini in relation to a straight edge. This was so the end piece of the exhaust could be cut at an angle and welded onto the backbox in a way which would allow it to sit flush with the mini body panel. Its welded on now, but this was it before (bear in mind I had to cut off one of the pipes coming off the backbox in order to weld my tail pipe on, So was out with the grinder and the tig welder:)
I cut the hole and took a picture when it was still very rough im afraid, Tis all nicely filed out now so the tailpipe just comes through.
Now, We just had to think of a way of securing the exhaust box the the panel. So fortunately for me, my good friend ben is very good on the old Autocad and 3d drawing programs. So a couple of hours round his and, we had thought of a way to secure it. This is what we(he) came up with...
This is the final design for the outside flange, There will be two the same and they are both two parts. The inner flange will be welded to the tailpipe and butt up against the inside of the panel. The outer will bolt through the panel onto the inner via the 10, 6mm holes.
These will be cut out of 1.6mm mild steel plate using a laser. Should be done tomorrow(courtesy of ben) lol.
Should look something like this when done(with a mini body panel in between)
Stay tuned,
Cheers, John
#28
Posted 16 March 2010 - 03:04 PM
#29
Posted 16 March 2010 - 08:32 PM
Might be able to help you thereNice project im looking to start mine very soon
just need a shell
http://www.16vminicl...ead.php?t=21210
#30
Posted 16 March 2010 - 08:56 PM
