2.0 Vauxhall Redtop Engined Mini!
BlueminiJohn
, May 18 2009 05:07 PM
36 replies to this topic
#31
Posted 17 March 2010 - 06:25 PM
Hi
Nice build so far, what type of webers did you buy the dcoe 152's or 152g's?
regards
regards
#32
Posted 21 March 2010 - 11:19 PM
Update on progress on the exhaust.
I got my flanges and started fitting them. Sorry for bad picture quality. The finished result looks like this...
#33
Posted 21 March 2010 - 11:24 PM
Hi
regards
I believe they are the 152,s. I bought everything as a job lot and the webbers were with it so not 100% sure. Ill try to find out.
#34
Posted 23 March 2010 - 12:40 AM
I built up the bulkhead box tonight, seemed easy enough to be able to justify not buying the allspeed one.
Some 1mm sheet, cut to size with a grinder and just tig welded it up...
Fitted
Fitted
#35
Posted 23 March 2010 - 06:22 PM
I know it's a bit late now but you will find water collects on the bottom of the box (not good - I had this with my Turbo box before I cut it out and returned it to standard). You could add a sloped insert I suppose,
JR
JR
#36
Posted 24 March 2010 - 09:42 AM
JR
It had crossed my mind. However the car is going to be used purely in dry weather.
I might fit a ram air feed in to near the box to dry it off if it should ever get wet.
John
#37
Posted 07 December 2010 - 07:28 PM
You seem to be at similar stage to us but our shell is painted. What info do you have on carbs to use in available space and where to get manifold. Interested in best option as injection system much too big for space
