Fitting Rc 40 Problem
21 replies to this topic
#16 Neildanks
Neildanks
    Captain Slow!!!
  • 889 posts
Posted 20 May 2009 - 09:00 PM
The Y Piece Is That Close To Each Other There Is No Room For Another Type Of Clip These Clips Look As Thou They Are Stronger Than A Normal Type Any Suggestions
#17 Pauly
Pauly
  • 4,213 posts
Posted 21 May 2009 - 09:18 AM
I would bolt the system together with 'c' clamps (exhaust clamps), it looks like you got the mounting brackets already fitted to the frame, so just bolt it on with the clamps onto the frame and the joints, and it will sit fine. You need to straighten you backbox up as its twisted to one side, have it so the box sits level.
Paul.
Edited by Pauly, 21 May 2009 - 09:21 AM.
#18 gav
gav
  • 700 posts
Posted 21 May 2009 - 09:46 AM
As MRA have just said, jubilee clips will not be good enough http://www.minispare.....20CLAMP 1.5/8
#19 Neildanks
Neildanks
    Captain Slow!!!
  • 889 posts
Posted 21 May 2009 - 12:01 PM
Thanks For That Ill Go AndGet Some Now
#20 Neildanks
Neildanks
    Captain Slow!!!
  • 889 posts
Posted 21 May 2009 - 04:30 PM
Just Finished Fitting Exhaust
Figured Out Needed A 63mm Exhaust Clamp For The Rear
And Used The RC40 Mount Kit
Chopped Of Welded Bars
Needed To Make Slight Adjustment ( Take A Nitch Out Of Subframe ) To Subframe As I Had Repaired With Sections I Had Made Myself But Obviouse Now They Where Slightly To Wide
#21 mars red mike
mars red mike
  • 1,500 posts
Posted 21 May 2009 - 05:56 PM
Little tip for you mate : get a hacksaw and trim the excess thread off the clamps or turn them the other way up. Mine used to spark up on every speed bump. Whilst pretty to look at it didnt do the exhaust much good.
#22 Neildanks
Neildanks
    Captain Slow!!!
  • 889 posts
Posted 21 May 2009 - 06:09 PM
I Will Do Thanks For That
