Carrying on from where i left off previously, I began by grinding back the nasties in the boot corner, and from underneath where the filler panel for the valance was hiding. Had to grind for quite some time to get it tidy, particularly underneath while laying on me back.
I also spent most of the day with a blow torch, scraping off seam sealer and dirt in an attempt to clean the boot.
Made up and tacked on the plate for the underside - gave up with welding upside down because was getting burnt
Last week i ordered some more paint from Frost. One of which was their Weld Through Primer, which is essentially zinc in a can. Being zinc it's supposed to be good at resisting corrosion, so i coated the whole boot floor in it. Before which i used a product from Dinitrol called RC900 which converts rust into some compound or the other that stops the rust being rust...or something. The pic 3 up shows purple metal which is the effect it has. Seems to work so far. I've got fed up with using POR-15, it takes too long to dry and it goes rock solid inside the tin once opened so i keep wasting it, plus it aint cheap!
Coated the back of the rear seat with grey primer
I managed to tip the min over and finished the plate welding
I had a frenzied attack at the other valance filler panel, and removed a plate that had been welded earlier this year. This time i treated the metal underneath properly, along with all the other metal at the back with RC900 - note the purple tinge.
The whole lot got a coating of zinc
Then the valance and corner pieces turned up courtesy of mini spares and UPS. I realised that the corner pieces have nothing to weld them to the boot floor, so i welded a piece on, and drilled holes for welding to the floor and eventually the valance.
Here it's on the car, i made the drilled holes too small for the weld to work properly so had to tack it on instead. They need to be 6mm in future.
Here are both corner pieces on the car. It took a while to get them in the right place with the valance held in place on the car with grips. The panels aren't a perfect fit but i don't expect them to be, every mini's different after all, but they're pretty darn good. Just going to need a bit of bending a bashing to get right. I just hope there's enough room for subframe mounts/bolts, something i didn't check...but that's where the old one came off from so it's got to be okay
Here's the new valance just held in place with grips
