Flame Kit
#16
Posted 13 August 2009 - 08:20 AM
#17
Posted 13 August 2009 - 08:35 AM
Who needs a flamer kit to make manly flames:
Mini flaming vid
Edited by Prawn, 13 August 2009 - 08:36 AM.
#18
Posted 13 August 2009 - 08:50 AM
Couldn't you just pull the choke out a bit rather than having it running rich all the time?
Dunno, butterfly is stick a bit open with chocke pulled out and this could affect the quantity of unburnt fuel in the gas.
Mini pete on here did something similar.
#19
Posted 13 August 2009 - 10:16 AM
look for the autoloc flamer kit, i used to have one but never fitted it, didnt want to cut my nice shiney rc40 up
can do a similar thing by revving the car then turning the key off and then back on a second later with the throttle still open,
jack
#20
Posted 13 August 2009 - 11:35 AM
they're bloody stupid anyway.
Mini flaming vid
Running a little rich prawn?
Mine does man flames occasionaly.
Although im interested too see how excactly this is wired up. Because I can't see how flicking a switch can turn off 1 coil and turn on another.
#21
Posted 13 August 2009 - 12:50 PM
Another benefit of doing this in a mini is the angle of the exhaust. At the endo of the exhaust pipe there is a kink making the exhaust point upwards at about 35degrees, this makes it harder for unburnt fuel to leave the pipe, and so it sits in the bottom of this bend. With correct placement of the boss and spark plug you can then light this fuel, creating a much more dramatic flame.
#22
Posted 13 August 2009 - 02:16 PM
just cut back abit of casing off the ignition wire and then wrap the cabling around this.
Which ignition wire? and what cabling?
Ben
#23
Posted 15 August 2009 - 09:35 PM
Didnt work at first because it got wired to the wrong negative wire on the ignition coil in the engine bay.
easy as that tom:P your confusing everyone.
joe
#24
Posted 16 August 2009 - 01:43 AM
Agreed, leave the stupid flamer kits to the chavs in their saxo/corsa/other bodykitted piece of rubbish.they're bloody stupid anyway.
If you're going to do it, let it do it properly.
#25
Posted 16 August 2009 - 08:43 AM
