My Mk1 Rebuild Project
#61
Posted 29 July 2012 - 08:36 PM
#62
Posted 30 July 2012 - 09:52 PM
#63
Posted 31 July 2012 - 07:25 AM
#64
Posted 01 August 2012 - 10:30 PM
#65
Posted 27 December 2012 - 01:12 AM
Good luck with your project.
#66
Posted 06 May 2013 - 06:16 PM
Wow. It's been a while since I updated this feed!
I would like to say quite a bit has changed, but up until last week it really hadn't.....
In September-ish, I gave the car a few coats of primer. Then the weather really started to turn naff for the winter, so I decided I could do no more until spring. There was no way I was going to risk painting the top coat with it turning cold and damp.
So I did not venture back into the garage to do any work really for the whole winter.
I did however get hold of a mk1 bonnet at a bargain price. Paid £30 for the bonnet and a box of bits and pieces, most of which I needed.
This leads on to last week......
#67
Posted 06 May 2013 - 06:44 PM
So my weeks Holiday finally came in which I planned to paint the car completely.
I had already laid down a good few coats of primer, and also given it a good wet & dry cut back before putting it away for the winter.
The weather couldn't have been better!
Wheeled the car out of the garage to check out the initial paint work already done, and give it another going over with wet&dry, reprep any really dodgy areas.
then it was onto the spraying.....
Then came the top coats. Over the space of two days put on about 10 coats of red on the outside of the car (about two or three on the areas inside that will not be seen)
Going to leave it for a good few weeks before I start thinking about cutting it back, but quite pleased with my paint standard overall
#68
Posted 06 May 2013 - 08:56 PM
that looks awsome! can not wait for mine to be at that stage.
#69
Posted 06 May 2013 - 09:50 PM
Looks great :)
#70
Posted 07 May 2013 - 06:10 PM
Thanks guys.
I'm feeling a lot better about the project. Perhaps I'll finish it by this summer........
#71
Posted 07 May 2013 - 06:29 PM
Amazing job you've done there
might have to get you to come spary mine
#72
Posted 07 May 2013 - 09:28 PM
looks amazing! cant wait to make a start on my mk2 now i have seen this! what a transformation!
#73
Posted 07 May 2013 - 09:51 PM
Aha! Give me a shout if you need any help.
Where in RDG are you?
#74
Posted 07 May 2013 - 09:57 PM
nice one..might have to take you up on that..some things are easyier with two pairs of hands same to you i'm usually around if you need help
i'm just up in Tilehurst so not to far away
#75
Posted 16 May 2013 - 06:59 PM
Small update.....
During the course of this project I bought the 2 doors needed.
One is in mint condition, just needs a clean up before painting.
The other has been stripped back to bare metal at some point in the past. This has turned into a nice layer of surface rust everywhere. It also needs a repair done to the frame at the bottom - the skin looks pretty much ok.
So I chopped out the rotten pieces
Fabricated up the pieces needed, welded them in, a touch of (pageant) blue paint to protect the surface and some seam sealant, and Bob's your uncle!
Hopefully, this weekend I can prep the doors up for paint :)
Edited by miniman_7, 16 May 2013 - 07:00 PM.
