I have developed a problem with my 1994 Cooper. In any gear below 3000rpm the car stutters under accelerattion. Above 3000rpm the car pulls strongly. Any help would be most welcome.
Stuttering
jconNOS
, Aug 25 2009 09:01 PM
2 replies to this topic
Posted 25 August 2009 - 09:01 PM
Posted 26 August 2009 - 02:17 PM
Hi,
Start with Sprocket's first step to troubleshoot the SPI here:
http://www.theminifo...showtopic=20533
Yours might have a clogged line, but follow all his directions. I had both leaky and clogged lines, resulting first in high idle (leak). When that was corrected, I had poor idle and erratic acceleration at low RPM due to the clog that prevented the MAP sensor from responding quickly.
Cheers,
Ivan
Posted 27 August 2009 - 04:22 PM
Ivan,I have developed a problem with my 1994 Cooper. In any gear below 3000rpm the car stutters under accelerattion. Above 3000rpm the car pulls strongly. Any help would be most welcome.
Hi,
Cheers,
Ivan
Cheers for the reply,
Joshua
