Digital Tachometer
#31
Posted 12 December 2009 - 02:44 AM
#32
Posted 12 December 2009 - 02:05 PM
#33
Posted 01 September 2010 - 08:35 PM
Yes!! It’s been awhile. Truth be told finding time juggling work and play has been extremely difficult of late. None the less to catch you up, I've been working on a project of mine for quite some time and finally I can see myself nearing the end.
I have designed from scratch a Tachometer to be used for a mini (or any other vehicle) that is constructed from digital electronic components.
The focus of my design was not to include any micro-processor IC`s. The reason for this is that microprocessors need to be programmed by the constructor. My design uses fairly standard IC`s that can be soldered together and will work for anyone with very little electronics experience.
I am writing a manual which is a step by step guide to the design and construction of this tachometer.
I have three things left on my list
1) Design stable power supply
2) Design good input signal filter
3) Design PCB layout
I post now to remind people that I have not forgot and have been making slow (very slow) progress. I’m now on the home stretch so expect design info soon.
Here is an animated attempt of showing progress and how it should work...
Tachometer4.gif 282.27K
15 downloads
TachAnimation.gif 411.08K
13 downloadsSincere Apologies
Leykor.
#34
Posted 01 September 2010 - 08:50 PM
something like that would be really easy to tie in to a custom dash install and would be a great acccessory to a Megajolt.
#35
Posted 01 September 2010 - 11:34 PM
I wish I could do electrics!
#36
Posted 05 September 2010 - 02:16 PM
Alex
#37
Posted 05 September 2010 - 06:11 PM
One thing to watch is how bright you have it, in day time you need it bright so you can see it but at night some units where to bright and burnt into your vision.
Second one is don't make it to sensitive as the numbers on tick over bounce up and down like mad.
Last point could they be made so the person could choose what colour they have to there match interior . might help sell them if you ever try.
My 10p worth
#38
Posted 06 September 2010 - 08:28 PM
I have definitely made the brightness a concern and have included a photo resistor (LDR) to adjust the brightness depending on the light conditions. This allows for a bright display during the day and a dim display at night. The initial brightness is also configurable via a variable resistor.
This design is quite sensitive but also quite stable.
I do not intend on selling any units, I will provide a detailed report for the design and construction. This will enable you to build the tach to suit your needs. You could replace the back plate with a different colour or the digits with blue ones etc.
Thanks all for the acknowledgements
Regards,
Leykor
#39
Posted 06 September 2010 - 10:17 PM
That would be awesome so I could build one!!
#40
Posted 19 September 2010 - 02:37 PM
#41
Posted 19 September 2010 - 07:26 PM
You`ll be glad to know that I`ve sorted out the power supply completely and have done half the PCB design.
The circuit is pretty much complete, except I’m not too happy with my input signal filter. The input signal is taken from the coil -ve terminal. This signal is not very clean and is found to be riddled with voltage spikes and signal oscillations. Any suggestions would be appreciated; currently I’m just using a diode clamp, a zener overvoltage regulator and a low pass filter.
Regards,
Leykor
#42
Posted 24 October 2013 - 02:12 PM
any updates on this?
