Downforce
Posted 29 August 2009 - 07:59 PM
spoilers are usless on front wheel drive cars because they push the back down. but they look good said my friend. anyway minis with spoilers what do you think.
also consider rwd conversion minis and front spliters. any thoughts?
Y/N?
Posted 29 August 2009 - 08:20 PM
b) They look rubbish on 'normal' street cars
Posted 29 August 2009 - 08:46 PM
Posted 29 August 2009 - 08:55 PM
Posted 29 August 2009 - 09:05 PM
A rear wing could be pretty useful on a Mini as grip is down to tyre contact area, the stickiness of the tyres and the force pushing them on to the road. Traction isn't really an isue at the sort of speeds where wings become effective so they aren't so much use on RWD cars for that either but for keeping the weightless rear end of a Mini pushed into the tarmac under braking...
Posted 29 August 2009 - 10:00 PM
As long as your front wheels are doing what they should, then it doesn't matter
Edited by Figs122uk, 29 August 2009 - 10:01 PM.
Posted 30 August 2009 - 05:08 PM
forget the bodykit and imagine wide arches. all matching colour
Posted 31 August 2009 - 07:56 PM
Posted 01 September 2009 - 06:50 AM
A chap I know works in the aerodynamics industry. When he bought his scooby wrx, he did some calculations regarding its spoiler. Seemingly, at normal speeds its effects are negilgable, and at 100mph it gives less that 15kgs downforce. On the other hand, it massively increases drag and therefor fuel consumption.
Posted 01 September 2009 - 07:01 AM
Spoilers on road cars are for looks alone. If you want usefull downforce, you need to fit something like a BTCC or F1 style rear wing.
Haha fail!
Posted 01 September 2009 - 09:18 AM
a) You'll only notice the effect of downforce at a track
Without meaning to sound sarcastic... if your point a) is correct can you please explain yourself, as I was unaware that race tracks created there own atmosphere??
Sorry but aerodynamics don't change between track and road... there different because we choose a different sort of aerodynamics on the road to a track, e.g. getting over speed bumps, fuel consumption etc.
But if you want to improve the 'performance' of a road car then track aerodynamics is a great starting point...
The mini has the aerodynamic sophistication of a brick
Perhaps that's the perfect reason to improve then...
And also somebody has definitely edited there post since I read this last night... who said spoilers would be inafective on a Mini because it's front wheel drive???
Anyway a couple of basic rules... which kind of concludes that spoilers are pointless on our beloved Mini's or in fact on most road cars.
1) A spoiler will assist any cars aerodynamic performance from 60ish MPH upwards. So with a car that has a top speed of 90ish is it worth it?
2) They are 90% beneficial for straight line speed or extreme speed cornering, neither of which 99% of road cars are capable of.
3) They create downforce (obviously) so they will slow your car down, however, they work best in conjunction with a rear diffuser/undertray, and if set-up correctly can even speed you up
Track cars have massive spoilers because racing is less about power and more about being able to take more speed through the corner than the person in front/behind you...
(most forms of racing have rules which mean all of the cars have the same (ish) power anyway, before I get told off for saying this).
Whereas road racing is more about keeping up with the person in front of you, and then having more power to overtake them on a safe straight...
The best advice to give regarding aerodynamic modification is pick a similar modern day car and examine the body attire differences between the basic model and the sporty model, manufacturers spend the money doing the design and development for you that way
Posted 01 September 2009 - 09:28 AM
www.carbonweezel.co.uk/testing
All data found il be up in a week or so, some VERY interesting facts found.
Ben @ Carbon Weezel
Posted 01 September 2009 - 11:21 AM
was just going to post that.Well another option is to take a mini into a wind tunnel and see if it actually works!
Ben @ Carbon Weezel
Posted 01 September 2009 - 11:29 AM
Posted 01 September 2009 - 02:19 PM
You know forewell what I mean, stop being difficult. Downforce is only generated at speeds higher than the national speed limit. Extremely rarely will you be cornering higher than that on a public road - therefore, the effects of putting a wing on your road car will really only be realised on a track.the lack of knowledge that is being given as advice in this topic is laughable (sorry)...
So yes, you agree with what I said.
