Alpine Type-r Search
#16
Posted 13 October 2009 - 03:14 PM
#17
Posted 14 October 2009 - 07:06 PM
#18
Posted 14 October 2009 - 07:18 PM
Heres the gear
Sub Dosnt say an exsact size but they're going to be pretty close to 12" i should admagine.
Amp 380mm wide. (about 15")
So im looking at 39" in total but thats touching so, idealy i need about 45" - 50" wide i rekon.
As for the box i was goin to ask some advise nearer the timefrom the website in the links. If i need ported i'll just cut a hole in the bx the side i need and if its sealed... then thats one less job for me
Posted 14 October 2009 - 08:07 PM
The Sub - brilliant! Top sub and lots of power handling
The Amp - Good for running two speakers and a sub but will not drive your sub as well as it could. It should be enough to start but I can guarantee you'll get bitten by the bass bug and want more power!
Alpine recommend the PDX 1.600 mono block amp to get the best out of that sub. Only problem is it's £70 more expensive than the MRP-F600 then you would still need a smaller amp to drive any speakers.
You could always try something like this ported enclosure if there is enough room
Edited by Brams96, 14 October 2009 - 08:08 PM.
#20
Posted 14 October 2009 - 08:14 PM
#21
Posted 14 October 2009 - 08:16 PM
#22
Posted 15 October 2009 - 05:46 PM
by the way im gong to be running two subs. But if 12's are to big with the amp aswll i'll downsize to 10's maybe.
you are going about it the wrong way, work out what size of box the subs need, a lot of newer subs only need a little over 1' cubed. thats 12"x12"x12" + whatever the sub volume is then work out what size 2 of these are and work out where you can fit 2 of these............... then and only then work out where to put the amp
perhaps building the box where the rear seats should be and have it 2" lower than the rear shelf, once its in then put a false deck on it with the amp above the sub box
just a thought
oh once its done ill give you a RTA and SQ and SPL mini (sorry for the pun) sound off with my 8" sub and my 6" fronts and my 2x24w single amp.....................................
Edited by monkeybiz, 15 October 2009 - 05:48 PM.
#23
Posted 15 October 2009 - 05:53 PM
What i meant was have the board with sub either side of the amp in the center, then behind each sub have the box needed.
If this makes sence laughing my ass off
Posted 15 October 2009 - 06:09 PM
#25
Posted 16 October 2009 - 12:32 AM
Posted 16 October 2009 - 03:07 PM
#27
Posted 16 October 2009 - 03:11 PM
#28
Posted 16 October 2009 - 05:49 PM
Edited by Brams96, 16 October 2009 - 05:50 PM.
#29
Posted 18 October 2009 - 10:05 AM
#30
Posted 18 October 2009 - 08:50 PM
