This is how i did my speaker pods.
Linky
I think i spent about £40 on materials plus a good 8 hours or so n building them.
The only thing i would do different if i did them gain would be to use Milkshake mix (trade name for a mix of filler and resin) instead of filler as it give you a better surface from which to sand, plus it doesnt go as crumbly as fine sand filler.
To make milkshake mix use 50:50 quantities of filler and resin but dont add either of the hardeners until you have mixed both together thoroughly. this should give you a consistancy which you can still paint on with a brush.
Im not going to ue my pods any more so if anybody is in need of any give me a shout.
Fibreglass Kits & Tools
Watso
, Oct 13 2009 09:50 AM
36 replies to this topic
#31
Posted 01 November 2009 - 04:37 PM
#32
Posted 01 November 2009 - 08:28 PM
My sub box plans changed too. I thought about it but decided to build the box out of MDF instead so it would be more rigid. I am however making the door cards speaker pods out of fiberglass & mdf so they should now work out better as I have all this info to refer back too!
They will be part of the door card and incorporate the pocket as well so it's all 1 piece, should look good when finished. I'll be posting pics in my project thread as I go.
Cheers for all the advice guys, keep it coming.
#33
Posted 03 November 2009 - 11:04 PM
Some more thread stealing!
As for the flex, my box has the same flex as an inch thick MDF one.
Although it does resonate a bit more.
Progression is slow on this!
12 hour days urrrrgh 6 days a week!
As for the shock mount, it just slots in over the top.
#34
Posted 04 November 2009 - 07:23 AM
I know what you mean, I've got 2 days left of 14 straight (9 of those nights, in a row)! Lucky I can do small bits at work.
I measured my box volume and it is 16L, exactly what is recommended for the sub so I'm happy with that. I just need to find a decent 4-ch amp now and mount it on the other side. I might do a fiberglass cover with lights for the amp, just to make it look good.
#35
Posted 04 November 2009 - 09:05 PM
A word of warning with lights and stuff like that! Its very hard to do without it looking tacky.
Simple is best in my books
#36
Posted 07 November 2009 - 07:40 PM
I will probably repaint the amp I get the same colour as the car and mount it in the drivers rear bin with a perspex cover and a couple of subtle lights to make it stand out. The moulded cover will probably end up being covered in the same material as the front of the sub box.
#37
Posted 08 November 2009 - 10:00 AM
Oh okay
My amps are maybe! very maybe going under my parcel shelf if they will fit.
