Failed Mot
Posted 21 October 2009 - 02:57 PM
Posted 21 October 2009 - 05:23 PM
hi my spi failed horribly on its mot the emissons are double what its ment to be has any one any ideas?? the oil temp was 98oc i fitted a new lambda sensor last week any help taken on board
normally an air leak causes these problems, check the vaccum pipes on the manifold to air filter and ecu and also make sure they are doing the correct test for a mini and not a normal cat test
dave
Posted 21 October 2009 - 10:48 PM
Posted 22 October 2009 - 08:10 AM
Posted 22 October 2009 - 09:23 AM
Posted 22 October 2009 - 09:43 AM
I'm not aware of this either, what different test is supposed to be done on a mini with a cat thats different to a normal cat test? cheers!
Posted 22 October 2009 - 09:55 AM
Posted 23 October 2009 - 03:47 PM
Posted 23 October 2009 - 05:20 PM
Posted 23 October 2009 - 05:21 PM
Posted 23 October 2009 - 05:33 PM
dave
Posted 25 October 2009 - 09:41 PM
Posted 25 October 2009 - 09:53 PM
Will putting a new lambda sensor in make any difference as the reading is taken from the tailpipe and not the sensor itself?
Dan
Posted 25 October 2009 - 10:09 PM
dave
Posted 26 October 2009 - 10:24 AM
