on the hub about three layers of thead has peald of. looks like i need a new hub.
can;t believe the hub has broken.
Posted 13 November 2009 - 12:16 PM
Posted 13 November 2009 - 10:48 PM
Posted 13 November 2009 - 11:24 PM
Posted 14 November 2009 - 10:43 AM
Posted 14 November 2009 - 11:52 AM
i know some one didn't do a good job so keeping the mini of the road and going to rebuild the whole front end.
changing everything that wears.
got a nice parcel coming from mini sport.
not very happy that some one fitted this.
just looking now for a pair of second hand hubs. good ones with bearings.
Posted 14 November 2009 - 11:11 PM
Edited by booton, 14 November 2009 - 11:11 PM.
Posted 14 November 2009 - 11:24 PM
well i can't see the problem with using a good set of hubs and bearings.
Posted 14 November 2009 - 11:37 PM
Posted 15 November 2009 - 12:19 AM
Posted 15 November 2009 - 12:30 AM
Posted 15 November 2009 - 06:40 PM
The joint comes under extreme stress if the suspension is set very low and if there are NO bump stops on the suspension - this loading could I suppose show up later - as you have found. Lucky it didn't happen at speed. It is easiest to work on the hub on a bench - but it 'can' be done on the car. You will need a ball-joint splitter, and a large spanner or socket to loosen the ball-nut that secures the joint. If the car has no bump stop or rebound stop - you should fit these urgently - and raise the suspension if it's too low.
