then honestly, i wouldnt be so supprised, as said by someone else previously the meer 18cc difference unfortunatly isnt going to make bugger all difference, it actualy a standard engineering oversize, one of which you dont neeeeeed to tell you insurance about (though it *shouldnt* hurt if you do so)
if you want more power take the advice elsewhere, work the cylinder head and uprate the cam...while ensuring the engines built propperly. Rather than getting expensive timing gear you can get offset keys which will allow the cam timing to be optimised...saying that im sure you want a drivable mini rather than an all out larey beast there for shouldnt go for a wild cam, you may well get a decent head but its usualy comes down to the lowest spec part limiting the engine, ie you may have a 300 degree cam but if the head breaths like an asmatic it will only produce the power according to the head, like wise nice large head but tiny cam opening times means you wont get decent amounts of air in.
Edited by mini93, 29 November 2009 - 01:24 PM.
