what size tank do you have?I have a Mpi with a stage 3 head, sw5i cam and k&n and the 48 mm alloy throttle body
I get really bad MPg driving around town. However I get bettter results on the motorways
I think I average around 180 on a full tank. 24 litres mine is.
Mike
Mpg/max Mileage From Tank On Mpi
#16
Posted 20 January 2010 - 10:05 PM
#17
Posted 20 January 2010 - 10:11 PM
when the needle is reading in the red there is at least another 5 litres still in there. EVERY car does this, its called the reserve. You look at the gauge and think you are going to run out, so you fill up, thus preventing you from running out. So, if you do run out, you have either run out of fuel on purpose, or you have ignored the reason the fuel gauge is there and its your own fault
#18
Posted 20 January 2010 - 10:18 PM
Is there anything to adjust so the gauge reads the true amount?
I think it would be better than guessig.
#19
Posted 20 January 2010 - 10:31 PM
When its in the red, fill up. Simples
If you decide to use the reserve without any indication, that is your own risk. All cars have this, its nothing new, its just that the mini tank is so small compared to most modern small cars
#20
Posted 20 January 2010 - 11:22 PM
#21
the most i have ever done is about 130 miles, and that was taking it real steady down to cornwall. With my guage, it is completly empty as soon as it hits the red line, is that good??
It seems that people are getting different readings.
#22
Posted 21 January 2010 - 12:23 AM
What is to say the last owner is thinking along the same lines as you and has bent the arm on the sender inside the tank so that it reads the dregs in the bottom of the tank when its too late and you have run out.The rate of the gauge changes with the level in the tank, thats just physics, the tank is an odd shape. a bent sender float arm will read lower further and quicker and full longer. There could be fuel in the float, and the stop adjustment of the float arm on the rheostat could have been tampered with. too many variables that the sticky fingered people can play with. Then there could just be the faulty or mal adjusted ones that have allways been like that. The majority of fuel gauges will read as they should.
Of all the minis I have had, carb or injection, it has been no different.
MPG using the mini clocks and the inacurate measuring by filling the tank once does not give you an acurate MPG figure. You need to do at least 1000 miles, and brim the tank to the exact same level every time and record the odometer reading which has been calibrated. Tyres, brakes, tracking, wieght all have a bearing on the final result and not nescisaraly a problem with the tune of the engine, although a combination of them all is not going to be obvious whats wrong.
Also note that there is another valid reason for there to be a reserve of fuel in the tank, and that is to stop the pump running dry. The pump does not sit right on the bottom of the tank.
#23
Posted 21 January 2010 - 12:46 AM
#24
Posted 21 January 2010 - 05:39 PM
I always thought my dial was 'off' because when i brim it, it never reaches the black line on the dial.
Mr Sprocket you seem to really know your stuff. How long have you had an mpi?
#25
Posted 21 January 2010 - 11:16 PM
As for crud, what sort of crud? Water will sit at the bottom of the tank, as will any dirt. Anything that is light enough to sit ontop of the fuel will be 'screened' out before the pump, and anything that does get through will be filtered out before it reaches the injectors.
'Crap in the tank' is an excuse used by garages as an explanation to a problem that they cannot easily explain. All the petrol tanks I have looked into, have been clean in the bottom.
Fuel contamination is different, lots of water will obviously cause a problem and silicone will damage the lambda sensor and cat (Tesco)
Edited by Sprocket, 21 January 2010 - 11:19 PM.
#26
Posted 22 January 2010 - 12:50 AM
