Dan says "Get an MPi Heater". I can't speak for the OP but in my case I am going to be swapping in a C20XE and all the transmission linkage required. I'm sure the standard heater would clear the linkage to the F20 but I really want more room as I am also going to be running a custom built center console, aftermarket stereo components, a whole mess of Autometer C2 gauges, and quite a few other things. I just want ROOM. I even thought about not running a heater at all so it isn't cluttering up under my dash. I'm a neat freak and want the wiring and such to be routed cleanly and not look cramped or cluttered.
The thing I dislike the most about the mini heater is how it hangs below the bottom dash rail. Why the heck did they do this?! My Dads old 1947 Dodge Power Wagon had a nicer looking heater setup. Also, when you guys talk about "demisters" do you mean "defrost"? Sometimes....even though we both speak English alot can get lost in translation so I want to be sure we are on the same page. To the few people that have cited examples where Aluminum has rot out on BMW's, Land Rovers etc....I did post a link from Wiki that explains HOW that can happen with Aluminum. If it is a Door skin then is the door frame made of Aluminum too or is it steel? (referring to the Land Rover) The article on Aluminum's Characteristics clearly states that it's corrosion resistance GREATLY reduces in the presence of other metals.
Regarding Dan saying it has no air controls (the unit I linked). What do you mean?! It is able to run different attachments that allow it to perform different functions. What kind of controls does my stock Mini heater have? Lets see....there is "Car", "Screen", "Off" and an on/off switch. The heater I linked is 3 speeds and for an additional $25 you can get a fancy kit to add air ducts. It wouldn't be hard to make that heater 150,000,000 times better than an MPi heater. 28,000BTUs! Now don't take what I am saying the wrong way (as it is hard to determine that over the internet), an MPi heater might be fine...I have never seen one. But the heaters in both my 1982 Mini's (1000HL, Mayfair) are craptastic.....there are alot of amazing design cues Sir Alec built into the Mini, the heater isn't one of them IMO.
If my wife & I get stationed in California or Florida after our tour is up here then I will remove the heater. But if we end up in Colorado then I need something I can depend on but at the same time fit nicely up under the dash in a compact type of way.
Edited by Trail of Dead, 26 December 2009 - 07:41 PM.
