Boot Lock?!
#16
Posted 08 January 2010 - 09:30 PM
#17
Posted 08 January 2010 - 09:36 PM
#18
Posted 08 January 2010 - 10:41 PM
#19
Posted 08 January 2010 - 11:15 PM
Apart from that Graphite Powder is the best thing for Mini locks as it lubricates the mechanism properly and prevents it freezing too. (Time I invested in some).
#20
Posted 08 January 2010 - 11:26 PM
and the graphite power is a good call there, im forever reccomending it but i have actually ran out ill give that a go 2moro before i try to take the whole lid off
thanks
#21
Posted 08 January 2010 - 11:31 PM
#22
Posted 08 January 2010 - 11:41 PM
just been out there... not good!
using wd 40 and a lighter on my key and stuff no luck!
if i want to get in there do i need to drill out the lock and replace it?
what mk is my mini its a 1989
toby
If you want to get in there, just remove the 4 boot screws from the hinges and the lid will fall off.
It more than likely needs the lock greasing. Just undo the 4 nuts that hold it in, strip clean and regrease.
Salted!!
they have nuts on the inside so may just spin !!
#23
Posted 08 January 2010 - 11:49 PM
#24
Posted 08 January 2010 - 11:52 PM
#25
Posted 09 January 2010 - 01:39 AM
Edited by charie t, 09 January 2010 - 01:40 AM.
#26
Posted 09 January 2010 - 01:41 AM
#27
Posted 09 January 2010 - 03:13 AM
on a more serious note, try unscrewing the hinges there is a nut on the inside of the boot so get a flat blade screwdriver and put it behind the screw head as your undoing it so its keeping the nut tight to the body work at the back and hopefully it will come off
#28
Posted 09 January 2010 - 03:14 AM
Edited by danny2009, 09 January 2010 - 03:18 AM.
#29
Posted 09 January 2010 - 10:03 AM
#30
Posted 10 January 2010 - 04:02 PM
