Gt Convertible Project
62 replies to this topic
#31 Junior Mini
Junior Mini
  • 313 posts
Posted 03 July 2010 - 07:46 PM
Humm, Yellow is a good 70's colour, but with no roof? Will it still look retro chic i wonder?
I will keep an eye on this with great intrigue.
I'm not for one minute saying it's wrong, just can't picture it. :D
#32 joe90gt
joe90gt
  • 288 posts
Posted 04 July 2010 - 06:04 AM
I'm open to suggestions but don't really want a metallic
#33 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 04 July 2010 - 10:41 AM
I agree, keep it a solid colour, I'm going Arum White for my Hornet saloon, and the pale green for the cabrio, I think, if I ever get that far...
I'm trying to think what might look good, not red - too obvious - maybe the primula yellow?
Or Yukon Grey?
#34 joe90gt
joe90gt
  • 288 posts
Posted 04 July 2010 - 04:18 PM
it was that slitgtly mustard yellow so i think I'll stick with that - needs to stand out a bit otherwise it'll get run over by other traffic - maybe I need to buy one of those luminous flags like the recumbants have.......
#35 joe90gt
joe90gt
  • 288 posts
Posted 04 July 2010 - 04:39 PM
Attached File  IMG_1770.JPG   275.04K   21 downloads
second door frame was a right mess - repaired now ready for skin - to think i swopped a serk alexander tank for two "good" doors - " good my arse.
damn i look like a gumby ( monty python) in that photo!
Edited by joe90gt, 04 July 2010 - 04:41 PM.
#36 joe90gt
joe90gt
  • 288 posts
Posted 07 July 2010 - 11:52 AM
got the other skin today so should be able to complete that at the w/e, gonna start prepping the interior for painting and change the diff seals because its weeing oil, saw what i thought was a keiths convertible mayfair at minimail but it turns out it was one minimail did ages ago and then keith's convertible's nicked the idea, but I still don't like the big T bar and window surrounds. Minimail really are a good company - luckily its only a few miles away for me
#37 joe90gt
joe90gt
  • 288 posts
Posted 11 July 2010 - 06:13 AM
second door wasn't so easy due to distortion of the frame so the door will need a bit of "fitting" before it goes back on - found some of the cellulose i used on the original rebuild so have started to brush paint the inside - doesn't matter about the finish too much because it will all be covered in carpet and seats - also did a bit more strengething around the pillars and some seam sealing
#38 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 11 July 2010 - 06:27 AM
not had one of these for awhile
#39 joe90gt
joe90gt
  • 288 posts
Posted 23 July 2010 - 06:59 PM
not much to report really - doors are done - a bit more welding done and now starting to prep for painting, was going to rub down and respray but have decided to go bare metal jus so theres no contamination, at least I dont have to do the roof now!
Scuttle and windscreen suuround are in really good condition considering they are original - the steel must have been stronger in the 70's from what I've seen of the some of the 90's minis here, amazingly when i took the windscreen out there was still liquid in the seal - she's been dry stored for two years!
Attached File  IMG_1792.JPG   280.07K   24 downloadsAttached File  IMG_1788.JPG   260.91K   15 downloads
#40 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 27 July 2010 - 01:26 PM
Looking really good mate, keep up the good work and keep the pictures coming! :wub:
#41 Adam the Flatulent
Adam the Flatulent
  • 54 posts
Posted 27 July 2010 - 09:02 PM
I wish my scuttle would meet the wing like that!
Edited by Adam the Flatulent, 27 July 2010 - 09:02 PM.
#42 rich2
rich2
  • 353 posts
Posted 31 July 2010 - 06:27 PM
I can't believe you chopped the roof off! Brave stuff, but awesome metal work skills!
I can't wait for the front end on my wreck to look like yours. Are you using a sanding disc on an angle grinder to strip the paint?
#43 joe90gt
joe90gt
  • 288 posts
Posted 01 August 2010 - 07:53 AM
i've tried everything - stripper, discs etc and the best and cheapest and quickest - although you have to be very careful not to mark the metal - is fine grit discs on a angle grinder, i also used scotch brite discs on a ag and although its effective without too much marking it works out expensive, where the metals marked I use a Da with 80 grit to get it smooth, paint stripper is truly a waste of money and effort for stipping big areas
#44 rich2
rich2
  • 353 posts
Posted 02 August 2010 - 08:14 AM
Cool. Thanks. I'll keep that in mind.
#45 joe90gt
joe90gt
  • 288 posts
Posted 10 August 2010 - 04:26 AM
Attached File  spray.JPG   404.19K   7 downloadsstarted spraying - had a bit of a prob with the gritty finish but that was soon sorted with some w&d, on a roll now
    Bing (1)
