Faster 998cc
#31
Posted 29 April 2010 - 11:27 AM
Philip, thats a very nice spec, it will be nice and torquey, and very smooth to drive!
#32
Posted 29 April 2010 - 11:44 AM
I'm currently building a fast 998, click on my sig for some ideas.
haha, thanks liirge, just looked through ure proj thread, love the retro look
Im gonna get that swiftune kit aswell, the one with the duplex vernier and oil pump. bit pricey but a must i think, how did u go on with fitting it? People seem to rave about that cam
#33
Posted 29 April 2010 - 11:56 AM
The SW5-07 is a fantastic cam, with very good driveability, however i have heard that it really isn't savage enough..i believe Shiftyseamus on here has one fitted to a 998, so try and PM him for info on the cam. I went for the SW10-07 as it's only a toy, so the no power low down wont affect me to much.
#34
Posted 29 April 2010 - 02:30 PM
Cylinder head
Carb(s)
Camshft and rockers
Electronic ignition (being least important).
Also worth studying the chapters about flowing the carb and inlet manifold. A couple of hours with a Dremel or file can get a single SU flowing as much mixture as a carb the next size up! Most stage one kits come with a K&N cone, which isn't much use without a ram pipe or stub stack inside. If you have standard airbox with a K&N element inside, try drilling a few big holes on the front to get more cold air in.
And I also agree with Pooky, best way to improve acceleration and fuel consumption is to shed weight!
#35
Posted 29 April 2010 - 05:12 PM
#36
Posted 29 April 2010 - 05:17 PM
Camshaft, Duration and then the Lift (mm) on the far right.
848/998 A+ Leyland 230/240 6.35 6
Cooper 998 BMC 230/252 6.35 6.35
SW5 Swiftune 244/244 7.14 7.14
MD256 Kent 254/254 6.66 6.66
Cooper S BMC 240/252 6.35 6.35
MD266 Kent 260/270 6.68 6.85
997 Cooper BMC 252/252 6.35 6.35
Edited by liirge, 29 April 2010 - 05:18 PM.
#37
Posted 29 April 2010 - 07:06 PM
MD246 Kent 252/252 7.23 7.23
and liirge if you are mentioning downdraught carbs in reference to the 28/36 Weber, on mine no modifications were/are needed to make it fit under the bonnet.
#38
Posted 29 April 2010 - 07:08 PM
What kind of Trumpets and filter are you running on that? also wondered if there's a better one, after doing some more research the 28/36 does not flow as much as twin SU's (HS4's).Which is why in my 998 build i am going for a Kent 246
#39
Posted 29 April 2010 - 07:23 PM
eh? does not flow as much? the 28/36 flows much better than a HS4. If you check the test vizard has done the 28/36 is far ahead (remember the 28/36 has changable venturis)
Edited by cap'n crunch, 29 April 2010 - 07:24 PM.
#40
Posted 29 April 2010 - 07:26 PM
#41
Posted 29 April 2010 - 07:34 PM
The SU (or webber barrell) which is not directly inline with the cylinder on its intake stroke is adding no extra air flow.
Edited by cap'n crunch, 29 April 2010 - 07:35 PM.
#42
Posted 29 April 2010 - 07:37 PM
just double checked my flow figures, and your right the SU is 142 and the 28/36 is 225....hmmm
Does she have that induction roar that side draught webers have.
Edited by liirge, 29 April 2010 - 07:38 PM.
#43
Posted 29 April 2010 - 07:41 PM
It's all swings and roundabouts but i know which one I would chose
#44
Posted 29 April 2010 - 07:44 PM
#45
Posted 29 April 2010 - 07:47 PM
On the first choke which is about 2/3 of the thottle movement it is quiet and sensible ( and decent fuel economy aswell) but get past that and open them both up and yep the full roar is there and it goes like a bullet.
Oh and the throttle response on the 28/36 compared to Twin HS2 I found was a no contest. 28/36 is much better, probably down to the fact the primary choke is small so air flow is fast. All this talk is making me really want to get my car rebuilt even faster I miss the weber fun!
