I had the same problem before and it turned out to be fuses, i changed all my inline fuses to blade fuses, the old fuse box was all coroded
Flasher Units
SprattBoy
, Feb 15 2010 04:09 PM
17 replies to this topic
#16
Posted 22 February 2010 - 10:41 AM
#17
Posted 22 February 2010 - 09:36 PM
just had same thing on my 1993 mini it was in line fuse tucked up behind carb .holder corroded so fitted new blade type and all works fine now
#18
Posted 22 February 2010 - 10:49 PM
It's probably the hazard switch - spray some wd40 into it - and switch it on and off several times - snapping it back and forth. Now try the flashers !
