Cheers for that!!If you get 10x5's and don't lower it too much then no body mods will be required, however if you do lower it (like I have) you will need to take a little bit off the front of each arch or the wheels will touch when at full lock/ full bump!
The arches are well easy to fit - put them in place, mark the holes, "carefully" drill them and then fix the arches in place with either rivets or self tapping screws!
the pain is to get the chrome trim to go on and stay on but there is a knack - hot water!!
:cheese:
:cool:
