Volvo Race Zcar
28 replies to this topic
#16 vulpina
vulpina
  • 33 posts
Posted 29 June 2010 - 02:48 AM
I went for the coolant line partially inside to be on the safe side .
I might be the slowest builder on here ,but here is what i am working on right now :
Raised gear lever ,home made and hand made ,
Still need to finish for the cable end fixing part .
Fixing for the pedal box , dont know if it will hold enough yet , i got some idea if i need to strengthen it :
Edited by vulpina, 29 June 2010 - 02:49 AM.
#17 Mini-Mad-Craig
Posted 29 June 2010 - 01:34 PM
Very nice, and looking good. I saw an after eight with a genuine gold roof at the London motorshow in 2008 -_-
#18 benmoffat
benmoffat
  • 347 posts
Posted 27 February 2011 - 09:38 AM
Looking great, love the wheel choice.
Only just found this project, is there any update on the build?
#19 vulpina
vulpina
  • 33 posts
Posted 31 January 2012 - 11:01 PM
Im getting back to work on the mini after a long pause :)
I am stuck on how to do the throttle cable ,from pedal to throttle body.
#20 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 01 February 2012 - 11:45 AM
Heres how I did mine, it removes the adaptor as used by Zcars - food for thought.
I ordered a throttle cable 750mm longer than the standard unit from Zcars and fed the pedal side up to where is shown in the photos below and you can see that when it came into the cabin of the car it was in line with the connection at the top of the pedal (you can just see the wire and the rose joint connector in the picture at the bottom:
By the way good to see your back on the build, I did wonder what had happened to the build...
#21 vulpina
vulpina
  • 33 posts
Posted 01 February 2012 - 06:10 PM
Thank you Cptkirk you are always so helpfull :)
So from the yellow arrow the cable make a "U" turn and goes back to the engine ?
There is not too much friction from the bend ?
One trouble i got , is that the volvo throttle body seem to need a lot of pulling to fully open , and i cant match it on the pedal movement if you understand what i mean .
I think i need a long top part of the pedal to have enough pulling movement .
Edited by vulpina, 01 February 2012 - 06:16 PM.
#22 cptkirk
cptkirk
  • 1,799 posts
Posted 01 February 2012 - 08:22 PM
You need to work out the linear movement of the cable in respect to going from closed to wide open throttle, then when designing your pedal you need to make the arc taken by the cable connector travel the same amount. I am going to guess and say that the linear movement is no greater then 50mm, it wont be hard to make this movement in an arc. Good Luck...
#23 vulpina
vulpina
  • 33 posts
Posted 31 March 2012 - 08:41 PM
Cptkirk , i cant do what you advised for the throttle cable , because i have the fuel tank in the way , my build is left hand drive , so my gas pedal is almost in the middle of the car .
Its really difficult to find how to do do it , it have stopped me for quite a long time now .
#24 2000lukey
2000lukey
  • 70 posts
Posted 31 March 2012 - 09:44 PM
Just an idea, but can't you weld a tube in the tank and pass the cable straight through? If its done well it would look good but understand its not the ideal for everyone.
#25 vulpina
vulpina
  • 33 posts
Posted 25 July 2012 - 02:57 PM
Hey Lukey , good idea , i sure can do it .
So far my motivation to finish the car was really low , because of this throttle cable problem i cant solve .
#26 2000lukey
2000lukey
  • 70 posts
Posted 25 July 2012 - 06:06 PM
I have got to do something along these lines now! As I have made a larger stainless fuel tank to sit upfront but it's blocking my anti roll bar off, did some drawings on the computer and it actually looks really good!!
Glad I could help. All the best with the build.
#27 vulpina
vulpina
  • 33 posts
Posted 28 September 2013 - 06:31 PM
Hello ,
Still nothing has moved on the car , iam really stuck with the throttle cable ,
Anyone with a volvo kit , left hand drive can help me get that throtte linkage done ?
the mini is gathering dust and i cant do nothing :(
Edited by vulpina, 28 September 2013 - 06:31 PM.
#28 Birdman
Birdman
  • 400 posts
Posted 28 September 2013 - 11:27 PM
I made my own floor mounted throttle peddle.  I used steel brake line for the housing and regular throttle cable for the cable.  Don't know whay it wouldn't work for you.
  • Attached File  177.jpg   41.95K   24 downloads
  • Attached File  178.jpg   47.84K   23 downloads
  • Attached File  176.jpg   55.01K   23 downloads
#29 vulpina
vulpina
  • 33 posts
Posted 09 February 2014 - 11:42 AM
Hi ,
how do you guys , volvo owner solve this gas pedal cable thing , i need to get back at it , i need some ideas please :)
Edited by vulpina, 10 February 2014 - 03:59 PM.
