Tappets For Idiots
43 replies to this topic
#31 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 16 March 2010 - 03:24 PM
did anyone else give this a go?
#32 mk1leg
mk1leg
  • 9,343 posts
Posted 16 March 2010 - 03:38 PM
I've been doing them this way for 36years ...................ever since I has a mini.............way back then.......... ;)
#33 Mart!
Mart!
  • 303 posts
  • Local Club: www.MainlyMinisMontreal.com
Posted 16 March 2010 - 03:48 PM
its also well described in the haynes book
#34 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 16 March 2010 - 04:06 PM
I have done it was was asking if anyone else that had not done it before i also have a haynes and it was a good tool ;)
#35 Ipod
Ipod
  • 2,024 posts
Posted 16 March 2010 - 04:09 PM
I got a haynes but was to lazy to open it up to the correct section ;) :D :o
#36 Spitz
Spitz
  • 1,716 posts
Posted 16 March 2010 - 08:09 PM
I got a haynes but was to lazy to open it up to the correct section >_< :thumbsup: :sneaky:
It's actually quite easy to remember....no need for Haynes.
Use the rule of "9"
8 is open check 1
7 is open check 2
6 is open check 3
5 is open check 4
4 is open check 5
3 is open check 6
2 is open check 7
1 is open check 8
notice they all add to 9. So, no need to check the book any more. If 6 happens to be closest to open when you start, check 3...rotate crank to whichever valve is due to open next...check corresponding number.
#37 cooperkelly
cooperkelly
  • 34 posts
Posted 24 March 2010 - 12:50 PM
In keeping with the name of the thread, and assuming I'm an idiot before I take the rocker cover off, what am I looking for when you say an "open" valve?
Thanks!
Kelly
#38 lrostoke
lrostoke
  • 6,923 posts
Posted 24 March 2010 - 12:53 PM
Watch the springs on the valves, when the spring is squeezed (compressed) the valve is open.
#39 Ethel
  • 26,583 posts
Posted 24 March 2010 - 01:35 PM
you can't have a tappets topic without the John Twist video!
fezXUwVfH7U
#40 cooperkelly
cooperkelly
  • 34 posts
Posted 24 March 2010 - 02:21 PM
Awesome!! John Twist had me a little lost at one point with his diagram, but I certainly got what he was saying!!!
One big question though- he states you should always do it with the engine warm... everything I seem to have read say it has to be stone cold?!!
:thumbsup:
#41 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 24 March 2010 - 03:06 PM
For performance engines, do we want 12 thou on exhaust, and 15 thou on inlet? Or is the other way around?
Edited by Ouster, 24 March 2010 - 03:06 PM.
#42 Ethel
  • 26,583 posts
Posted 24 March 2010 - 03:16 PM
Warm or cold would depend on if the figure you have is for a warm or cold engine. Warm would be better, if you have both, as the engine will obviously be warm when it's running - just avoid getting burnt. Of course, it would also be difficult to set it warm if you're still in the middle of building your engine.
15thou exhaust - it gets hotter.
The point JT was trying to make with his diagram was that you don't have to fiddle about getting one valve (eg 7) exactly at maximum lift to check the other (2) - the clearance gap will be exactly the same for a long way either side of max lift on the other valve.
#43 tmsmini
tmsmini
  • 760 posts
  • Local Club: MOASF
Posted 24 March 2010 - 03:51 PM
It is also easy to rotate the MPi engine with a hex socket in the alternator pulley.
Terry
#44 Ipod
Ipod
  • 2,024 posts
Posted 24 March 2010 - 11:49 PM
Terry
Even esier to jack the N/S up stick it in gear and turn the wheel clockwise :(
