On our doors you would normally just use the standard hinges. The mounting side of the door should be strengthend (sp) with this in mind already.Got a pillar drill?
You could just drill loads of holes in the old hinges
If not, just use a piece of 3mm aluminium flat running full height on the inside of the door jamb to spread the load as mentioned above.
Can you get to the inside of the door? I thought the inside was blanked - how do you tighten the nuts onto the bolts?
As for sizes, the mounting holes for the hinges should be edtched into the moulding already for you.
Les.
hi les,
the doors are not blanked. They have inbuilt door cards so i have to cut out a section to get to the tob nuts and then another section to get to the bottom or else..... i can just cut out the whole door card and then get new ones however as i also have polycarb windows i dont see the need to cut it all out unless i have issues installing the locks!
