9971 replies to this topic
#5971 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 20 July 2016 - 07:31 PM
Finished off the floor repair and fitted the interior  :proud:  Nearly there.
#5972 The Clubby Hubby
The Clubby Hubby
  • 555 posts
  • Local Club: Friends with minibitz
Posted 21 July 2016 - 06:46 AM
Welded headlamp panel and new bonnet slam panel to the clubby😀
#5973 Mini-dale
Mini-dale
  • 23 posts
  • Local Club: Anominis
Posted 21 July 2016 - 04:11 PM
Watched oil drip all over the drive then cleaned the oil up.
#5974 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 21 July 2016 - 04:25 PM
New starter solenoid fitted. Also fitted a new battery so the red one starts under its own steam. Head retorqued. Just need to sort out an exhaust from the manifold back, and a few heater pipes, bleed brakes and she's good to go.
#5975 Batmini
Batmini
  • 378 posts
Posted 22 July 2016 - 05:14 PM
Took it to Hitec motor sport in Kidderminster for rolling road session. 96bhp (calculated) @ flywheel and 90 ft/lb torque, but more importantly got the rough running at low revs sorted (fingers crossed).
Apparently if your carb is full of rust the engine don't like it !
Had the carb stripped and cleaned, fuel line blown through, new needle and valve in carb, new plugs + rolling road. Not bad at £180
Next on the list is an in-line fuel filter
#5976 AustinLeonardAutomotive
    Formerly IND00
  • 86 posts
Posted 22 July 2016 - 06:05 PM
Sold my 1975 Innocenti 1300 last week, but today I'm going to look at a 1981 Leyland Clubman 1275GT! :)
#5977 RooBoonix
RooBoonix
  • 1,225 posts
Posted 23 July 2016 - 12:36 PM
Over the last few days I've fixed my front indicator not working (bullet connectors behind grill had corroded alot, replaced with soldered wire joints) and also fixed some funny noises being caused by excessive engine movement.. fixed by tightening loose engine steadies and fixing a lower steady which had a bolt snapped. Much better but still wanting another steady/upgraded bushes to hold the engine even tighter in position.
#5978 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 23 July 2016 - 04:20 PM
Something I've been putting off for a long time:
Attached File  image.jpg   69.64K   14 downloads
#5979 Mat
Mat
  • 254 posts
Posted 23 July 2016 - 05:11 PM
Removed my lovely but too large Alfa 156 seats, and fitted some tatty but pretty cool Mx5 ones:
EDCCA115-C2FA-46CE-8EB0-E592581CADCB_zps
#5980 Lordcroker
Lordcroker
  • 42 posts
  • Local Club: Midweek Minis
Posted 23 July 2016 - 07:24 PM
Whilst looking for some rag, realised that the old bit of rag that the original headlights for my car came wrapped up in is actually a Wood and Pickett tailored car cover! It's shrunk a bit though.....
#5981 fenghuang
fenghuang
  • 796 posts
Posted 23 July 2016 - 08:19 PM
New dizzy and coil.
Set the timing and fuel mix.
Test dive ... and ...it's actually not too bad. Running a bit lean, but that's easy and otherwise it's quite nice to drive.
Only downside, the ****** speedo isn't working now.
#5982 Chris.Williams
Chris.Williams
  • 679 posts
Posted 23 July 2016 - 09:48 PM
Removed my electric fan, going back to the yellow plastic one, if it ain't broke, don't fix it.
Good time to fit my new heater, got one of those real little ones from Minispares.
#5983 Batmini
Batmini
  • 378 posts
Posted 24 July 2016 - 12:54 AM
Removed my lovely but too large Alfa 156 seats, and fitted some tatty but pretty cool Mx5 ones: EDCCA115-C2FA-46CE-8EB0-E592581CADCB_zps
I've got the same, just recovered mine
#5984 Mat
Mat
  • 254 posts
Posted 24 July 2016 - 07:28 AM
They're really nice! I was thinking of denim to match the door cards...
#5985 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 24 July 2016 - 07:03 PM
Couldn't find a servo takeoff for the manifold, so cut down a spare oil filter pipe and used the banjo assembly.
Found a suitable length of pipe for engine breather.
Finished preparing the rear end for a new valence when it turns up.
Ordered the final few bits and pieces.
9 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
    Bing (2)
