9971 replies to this topic
#6181 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 14 October 2016 - 02:44 PM
finished making my stainless heater pipes. with stainless screws and clamp brackets.
#6182 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 14 October 2016 - 04:29 PM
Looks great, quality workmanship.
#6183 Cooperman
  • 23,566 posts
Posted 15 October 2016 - 11:39 AM
Fitted engine back in at last hope to have it running soon .anybody had trouble with fitting engine mountings with captive nuts I ended up removing nuts and fitted original nut and bolts .
There is a lot of advice on here telling folks not to use the mounts with the cr**py captive nuts. If you want trapped nuts then buy standard OE mounts and weld a pair of 5/16" UNF nuts on.
The ones with the trapped Riv-Nuts are just junk.
#6184 1984mini25
1984mini25
  • 8,850 posts
Posted 15 October 2016 - 06:42 PM
Also I've always been told that you should fit bolts with the nuts on the bottom wherever possible. that way if the nuts loosens and fall off the bolt will stay in place. With is the opposite to how the captive engine mounts fit with the bolts being fitted from below.
Still I've never had a problem getting the original engine mounts to fit, using nothing more than a old flat bladed screwdriver to align the holes. And using some masking tape over the ring end of a spanner (1/2" if using the correct bolts) and the head of the bolt pushed into it to keep it in place and held long enough to get the nuts tightened up from underneath.
#6185 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 16 October 2016 - 04:31 PM
Today (well last night I finished really...) I did this :)
From this....
To this :) ....
Im happy with the result, not that hard to do to be honest but I ran out of gas for my MIG welder half way through fitting the left light LOL
Just need to get meself a Mk1 grille and surround and the conversion plate for the bootlid....
#6186 minifreek1
minifreek1
  • 1,260 posts
Posted 16 October 2016 - 05:14 PM
Also realised that I had no filler to make the conversion look good, so painted it anyway....
Will be finishing the conversion properly, next weekend.... weather permitting LOL
#6187 scrumpix
scrumpix
  • 453 posts
  • Local Club: Yeovil Mini Mania
Posted 17 October 2016 - 11:44 AM
mot and pass
#6188 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 21 October 2016 - 11:14 AM
Fitted my new rear window sticker
Edited by Northernpower, 21 October 2016 - 11:16 AM.
#6189 minifreek1
minifreek1
  • 1,260 posts
Posted 21 October 2016 - 01:26 PM
I like that.... where from...?
#6190 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 21 October 2016 - 03:32 PM
Ebay. There are quite a few different designs.
#6191 GraemeC
GraemeC
  • 7,472 posts
Posted 21 October 2016 - 04:04 PM
Got it ready for tomorrow's Northumberland Borders rally:
http://northumberlan...ersrally.co.uk/
#6192 alex-95
alex-95
  • 6,078 posts
Posted 21 October 2016 - 05:14 PM
Drained the oil...
the holes next to all the bit's are 5mm >_<  doesn't look like the engines going in this weekend
Edited by alex-95, 21 October 2016 - 05:16 PM.
#6193 Zach P-D
Zach P-D
  • 444 posts
Posted 21 October 2016 - 09:47 PM
Realized how much of a project my Mini will be, so started looking at a 2nd one to drive while doing mine up.
#6194 Davey3legs
Davey3legs
  • 36 posts
Posted 22 October 2016 - 07:33 PM
Wanted to remove the water pump as the engine in the cooper i'm doing up has been stood about 10years, the coolant has turned to what i can only describe as 'puke'.
No problem i thought, remove radiator and unbolt.....radiator mount bolt is a bit of rust.
3 hrs later and lot of broken dremel sized discs i managed to cut the bolt off (the front panel is off and i still struggled, dunno how you remove the radiator if the bolt has seized any other way without dropping the engine!!).
Small victory, 1 hell of a long way to go.
Edited by Davey3legs, 22 October 2016 - 07:34 PM.
#6195 Jmadry
Jmadry
  • 41 posts
Posted 23 October 2016 - 03:27 PM
Tried and failed miserably to remove the rod change roll pin in order to replace the gaitor that covers the gear change seal.
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
