Sill Welding Costs
#31
Posted 26 April 2010 - 01:11 PM
if we use the example you gave any body shop that replaces a panel must seam weld it on and that is impossable in most cases.
#32
Posted 26 April 2010 - 04:39 PM
Had it checked out my my dads mate whos an mot tester with Kwik fit, he said it was fine, probably stronger than factory
Edited by miniman24, 26 April 2010 - 07:49 PM.
#33
Posted 26 April 2010 - 07:43 PM
#34
Posted 26 April 2010 - 07:45 PM
If you are putting a new sill on the car its a replacement panel, not a repair panel so you can either seam weld, spot weld or plug weld or a mixture of them all and if the welding is up to MOT standard it will pass.
its only repair panels and patches that have to be fully seam welded.
Finally, something we agree on!!
He's right, if you fit a replacement panel, then it can be spotwelded as per the original.
#35
Posted 26 April 2010 - 10:31 PM
#36
Posted 26 April 2010 - 11:34 PM
heres what i found under mine after a removing them and poking with a screw driver
as for the replacement panel thing, my understanding is if its a patch it must be seam welded but if its a replacement panel it can be spot welded as the factory or equivalent ( plug weld)
#37
Posted 27 April 2010 - 07:51 AM
thing that gets me....why the *heaven* do they keep making and sellin the *silly* things!?
#38
Posted 27 April 2010 - 08:09 AM
i have this problem with oversills myself atm-just getting all replaced today.
because they are a bodgers best friend and a lot cheaper than sorting it out properly, especially if some dishonest person wants to sell their 'rust free' mini, my mate has first hand experiance of that - he wasnt best pleased when he found out and the seller wasnt interested.
#39
Posted 16 May 2010 - 07:34 PM
The other argument regarding seam welding, would this be a case of seam welding the sill to the floor between the drainage channels?
Final one (for now) do I attach the top of the sill by drilling holes in the doorstep and plug welding through to the new outer sill?
Bergy
#40
Posted 16 May 2010 - 07:41 PM
Rich
#41
Posted 16 May 2010 - 07:42 PM
