Hydrolastic Pump Question
23 replies to this topic
#16 kez_19
kez_19
  • 946 posts
Posted 26 April 2010 - 05:06 PM
wow that's alot is that achievable with a hand grease pump?
#17 midridge2
midridge2
  • 1,794 posts
Posted 27 April 2010 - 08:35 AM
http://www.austinamericausa.com/ go to tech section then suspension, its the same type of hydro set up.
its 27 inches of mercury for the vacuum side. hope this helps.
#18 MRA
MRA
  • 7,607 posts
Posted 30 April 2010 - 01:02 AM
If you simply pump it up to height and allow to settle for a few days if there is any air in the system it will find it's way to the top, ie valve you can then release it as you would air out of a tyre.... you may then need to pump it up to height again :)
The reason for the vacuum is to displace all air from the system so that when it is pumped up it is correct, this is good for a commercial enterprise as it means that you could go in get your system evacuated and pumped up and pay & go fairly quickly :) however hopefully you not in such a rush...
Edited by mra-minis.co.uk, 30 April 2010 - 01:02 AM.
#19 kez_19
kez_19
  • 946 posts
Posted 30 April 2010 - 04:28 AM
now that sounds like a good idea to me i am in no rush at all so this might be the solution
but thinking about it wouldn't all the air be left at the bend above the front suspension? if so how do i get the air out then?
#20 kez_19
kez_19
  • 946 posts
Posted 30 April 2010 - 04:30 AM
here is a page that i found that can convert loads of different numbers eg length, weight and pressure
converter
michael
#21 MRA
MRA
  • 7,607 posts
Posted 30 April 2010 - 07:51 AM
Yes but that is why you then release a bit of the fluid..... it pushes the air out at the same time
#22 kez_19
kez_19
  • 946 posts
Posted 30 April 2010 - 08:30 AM
oh ok i will be getting a pump in the near future so i will be able to test this and see how i go
thanks for all the help
#23 Ethel
  • 25,932 posts
Posted 30 April 2010 - 10:13 AM
Making several hundred psi is easy if you have a small enough pump and a big enough lever - 1/4" bore is 1 over 16 x pi = 0.2 sq in. Even pushing directly on that would need just 60lbs to make 300psi. You'd never totally evacuate the system with a vac pump. Bleed it as MRA suggests, but just fill it first, then remove the air (lower the car to compress the displacers). If you pressurise it with air in, it will dissolve and be like trying to bleed the gas out of a bottle of coke.
#24 MRA
MRA
  • 7,607 posts
Posted 30 April 2010 - 10:32 AM
Yes that is right, let the car sit on the bump stops prior to charging the system :)
gases under pressure will dissolve in a liquid as Ethel states the coke bottle ..... but if you let it stabilise the air bubbles will rise up and a quick release of some of the pressure will dispel the air with enough velocity that the fluid simply pushes it out :)
