Brake Pads
34 replies to this topic
#31 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 19 May 2010 - 04:34 PM
Have a Banana Burny :dontgetit:. I can only think that the squeel may go when its all bedded in? Nice speaking with you today :D
#32 Burnard
Burnard
  • 3,350 posts
Posted 19 May 2010 - 04:48 PM
took them out, and put copper grease on them by the way, didnt make any difference :D
(front shocks also fitted at the same time see other topic)
#33 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 19 May 2010 - 06:09 PM
All you lot complaing about brake fade. Get some Decent Brake fluid.
Its mostlikely the fulid geting to warm, therefor not working as effectivly.
The pads often work a differant tempreatures. But ive heard from lots of people EBC Green STUFF is poor and not what its made out to be. Personaly id stick with standerd pads from a decent manufacturer,Mintex,Unipart,Ect.......
If your still suffering Get some good Discs. The better discs will disopate heat better and work better in high breaking conditions.
There are many disks to choose from.
Grooved are the best in my opinyon as the groves help clear the disk of dust and water, they also aid cooling without weakening the disc to much.
As you are tecnicly removeing some of the brakeing surface you loose some braking capablity when the brakes are cold. But this is made up for once the brakes are in use and warm.
Drilled discs are not as good as groved as the holes can trap dust they also have a lot less of a contact patch. These hole also weaken the disc quite alot. Cheap drilled discs often suffer from fractures when they get warm. Altho they do disopate heat verry well.
Vented Disks are the way to go But these are hard to get on a mini without changing calipers and so on...
Id definatly go for some good Fluid , some decent standerd pads , and groved disks if i was still geting the problems.
Also if you want a decent pedal look into some braded flexi hoses. They do not buldge under presure like the standerd rubber flexi hoses.
bradid flexys may also help to create abetter pedal as the pipes
Thanks for that Joe, but you are wrong one one point, vented disc's are not the way to go on mini's, because the car is so light and has so little power they will never get hot enough to work properly. You will only need them if you have one serious engine under the bonnet.
thank you for the corection much apritiated.
I prasumed if they were having so many problems with stoping that who evers reading had some seriose power i.e turbo like MG metro turbo brakes light car lots of power big brakes.
#34 mini13
mini13
  • 3,811 posts
Posted 19 May 2010 - 06:50 PM
fade and the fluid getting too hot are two very different things.
#35 Cooperman
  • 23,340 posts
Posted 19 May 2010 - 06:59 PM
Modern fluid will not normally boil under road use and until it does boil it will perform as normal.
On my rally Cooper 'S' I now use the Carbon-Metalli pads as they simply don't fade, even when the discs are glowing red hot (literally). The standard DOT4 fluid would not take those sorts of temperatures, however, so i use AP600 racing fluid.
My standard 7.5" discs and 2-pot calipers (as per historic motorsport regulations) are superb under all conditions with this set-up.
