Florence My '97 Cooper
#121
Posted 01 October 2011 - 07:17 PM
great thread by the way i just red the whole thing, keep up the good work
#122
Posted 05 October 2011 - 11:40 AM
Update coming shortly if I ever find my camera lead!
#123
Posted 05 October 2011 - 12:03 PM
Anyway, good news
Now it's had around a week to dry, I went over the new paint with the rubbing compound and polish. It came up quite well, but if you stick your head by it, you can still see the transition between the paints. I don't know if its an issue with new/old paint (the wing's paint is 15 years old), the way I sprayed it, or if I didn't put enough/put too much on. Either way, it's done now, and I'm happy enough with it. It looks smarter at least than having a hole beneath the light and bubbles on the front/wing.
Paint finished by bcjamesmini, on Flickr
With that done, the front could all go back together. It's so great to see it looking like a road-going car again!
Front end! by bcjamesmini, on Flickr
I've also cleared space and sorted out all the nuts, bolts, and brackets for the rear subframe. All the other parts have been repainted in a satin finish ready for reassembly.
Rear subframe components by bcjamesmini, on Flickr
I found these photos on my phone too, it's a shame the car is going rusty as the paint can shine up quite nicely! Excuse the graininess, it's an iPhone!
Right by bcjamesmini, on Flickr
All being well it will be back on it's wheels and ready for it's first drive tomorrow. First stop, petrol station! Then it can come back for a head retorque and oil change.
Edited by bcjames, 05 October 2011 - 12:06 PM.
#124
Posted 05 October 2011 - 05:38 PM
Powder coated subframe by bcjamesmini, on Flickr
How nice does powdercoating look!!
New nuts by bcjamesmini, on Flickr
So after an hour and 3 cups of tea, I had this:
Subframe built up by bcjamesmini, on Flickr
Then, awkwardly got it here:
Subframe under by bcjamesmini, on Flickr
And finally...
Subframe in by bcjamesmini, on Flickr
Brakes are all back together, both hydraulic and handbrake. Fuel pipes are all connected. I was putting the suspension in when the boot came off of the cup on the knuckle joint. I'd tried so, so hard to keep them on. So, the annoying awkward job of getting it back on is first thing in the morning! When I fitted new suspension I had the knuckle and boot together, then slotted it in and used the cars weight to press it in. Since the cup is already in the arm, this will be a bit more difficult! Looking at those photos, I think I need to rub down and repaint my rear valance too!
#125
Posted 05 October 2011 - 05:44 PM
Dan.
#126
Posted 05 October 2011 - 06:09 PM
There's no ridge between the new and old paint, it was flatted to blend it in between prime, base and clear. After compounding there is no discernible difference in the surface between new and old. In just the ambient light of the garage it hard to tell, but shine the LED light on the area and you can see a difference in the colours. I'm yet to see how it looks in sunshine! Chris had a look and says I should have had a much darker primer or maybe needed another coat of green. Given my experience of spraying yellow over both white and grey primers, I'd say I needed a darker primer, it seems to be too light as you look in to it's depth, if that makes any sense.
I wish the garage was double width, my back is feeling squeezing between the wall and the car to fit parts!
#127
Posted 05 October 2011 - 09:08 PM
(Read that back and not sure it came out right but hope you get the compliment
#128
Posted 05 October 2011 - 09:35 PM
In truth, I just don't do a lot to it! I'm not in a position to rebuild it, and I'm not fussed on making it faster, sportier, etc. It's quite a nice car as Rover intended, so I'm not overly compelled to mess with it beyond maintaing it.
I'm really excited at the prospect of driving it again tomorrow!!!
#129
Posted 05 October 2011 - 09:37 PM
Edited by Peskett, 05 October 2011 - 09:38 PM.
#130
#131
Posted 05 October 2011 - 09:38 PM
#132
Posted 05 October 2011 - 09:40 PM
Woo three posts there!
#133
Posted 05 October 2011 - 09:45 PM
I'm really excited at the prospect of driving it again tomorrow!!!BRG Coopers are the best!
Max totally agrees
#134
Posted 06 October 2011 - 11:35 AM
Max totally agrees
Some more steady progress today. I couldn't get the knuckle boot to go back on, so I had to take the radius arm back off. After faffing around with that for about an hour and a half, I got the drivers side together in about ten minutes! I love the way a newly built up subframe looks
Passenger side complete by bcjamesmini, on Flickr
I also got my nice new stainless petrol cap on. It's the new one from Minispares. It's a really tight fit but looks smarter than my old one. For some reason the old cap was vented, where as this one is non-vented. As far as I know it's the latter I need on an MPi.
New petrol cap by bcjamesmini, on Flickr
Once the exhaust is rehung and parts are greased, the car can go back on it's wheels. My grease gun is being a pain and won't push any grease through, so I'll get messy trying to fix that!
I also can't get my rear brakes to bleed. I have hooked up the eezibleed, opened the passenger side rear nipple, and nothing. No fluid gets pushed through from the front. I've not done rears before, so don't know if I'm doing it wrong or if theres some other issue.
Edit: all that code came back, it seems to be when I use smileys and flickr in the same post.
Edited by bcjames, 06 October 2011 - 11:40 AM.
#135
Posted 06 October 2011 - 11:41 AM
