Good effort Graham. Get the glass in.
Mini Virgin Rebuild Of 83 Mayfair.
#961
Posted 12 October 2015 - 05:38 PM
#962
Posted 14 October 2015 - 01:24 PM
Well done Graham
Keep going, soon be done
I have followed your project since the start.
I too was building a Mini for my Son.
Some of the stages of welding we were doing the same stuff
Great work, Would love to se it when its done.
#963
Posted 16 October 2015 - 02:29 PM
#964
Posted 16 October 2015 - 06:48 PM
#965
Posted 19 October 2015 - 07:54 AM
No Graham its not for me
The first one was involved in an accident
I'm starting all over again with a new shell, then putting all the bits back on that one.
#966
Posted 20 April 2016 - 07:33 PM
been a while, again but hopefully I have found my enthusiasm again !!
Wheels now like this, just need lacquer
Untitled by graham adamsn
Untitled by graham adamsnI had an issue with a leaky brake caliper that ruined my nicely painted caliper I used some brake line sealer on the sealing bolts and bleed nipple aswell as cleaning the seats properly, seems to have done the trick, but paint job need a bit of work
Untitled by graham adamsnThe mini had become a Winter dumping ground so this morning I cleaned it out and voila
Untitled by graham adamsnclean as its been for a good while so continued on with the sound deadening I started a long long time ago, same flashing tape heated and smoothed into place.
Untitled by graham adamsnI was on a roll inside and got carried away so I put the interior inside.
Untitled by graham adamsnThe interior being in has given me the boost I was lacking and I can now see the end in sight. More fiddling tomorrow in the engine bay which should bring the MOT soon. However a few years on the car without moving leaves the ******* rubber these days like this
Untitled by graham adamsnAs I have said before, back in the game lol
Graham
Edited by grahama, 20 April 2016 - 08:17 PM.
#967
Posted 20 April 2016 - 08:01 PM
was thinking about this build earlier, good to see its still on the go
keep at it!
#968
Posted 20 April 2016 - 08:41 PM
Good to see an update, must be pretty close now. bloody annoying about the rubber parts these days, I had to replace 2 year old brake pipes as they had perished.
#969
Posted 21 April 2016 - 07:53 AM
Glad to see you back on the Mini Graham
not long now.
#970
Posted 29 April 2016 - 07:51 PM
Hi all,
thought this was behind me lol....
[/url
went to check the electrics after burning the wires when i tried to start the mini with it wired up wrong. Hazards, interior, brake test circuits not working, and blowing my power supply fuse. So after an afternoon of trial and error i decided to whip it out and strip the section around the fuse box and look for a short.
no burnt or shorted wires so checked and checked and then finally decided to look at the fuses. The hazard fuse under the scuttle was showing ok when tested but didn't work, very confusing, but once swapped it worked fine. The brake test switch was a combination of poor switch and a wire wrongly connected, all sorted.
i decided to move the connections for the rear and front loom and fuses inside while the loom was in bits again, seems sensible to have them inside and away from the elements.
all re wrapped and changed about.
I have thought about changing the mini switches for toggle ones as my switches are crap and temperamental. I worked out via internet help some diagrams, hazard being the worst to sort but here it is, and it works fine.
Wired up the relays and found some 3mm banana connectors to fit into the existing blocks as didn't want to remove them just incase i wanted to go back.
[url=https://flic.kr/p/GEpvuy]
[url=https://flic.kr/p/GhChAC]
Wrapped up and ready to install when I sort there dash and get the toggles
[url=https://flic.kr/p/FM9RsU]
At least it is sorted now and toggles on the way to replacing the crappy switches i have.
Moving on again.
Graham
Edited by grahama, 29 April 2016 - 08:23 PM.
#971
Posted 06 May 2016 - 09:55 AM
I have just read the whole thing over the last two days! Fantastic work sir! ![]()
#972
Posted 06 May 2016 - 08:35 PM
I have procrastinated a lot over the last couple of years to be honest, blaming the weather etc, but I just lost heart a bit. I am back on the case now and want it running this summer.
I have some time off now so as long as the weather holds I can get on, but am stuck inside at present fiddling with the loom, changing switched and sorting a dash. Pics to follow soon when I have an update worth posting.
Regards,
Graham
#973
Posted 06 May 2016 - 08:41 PM
Keep up the progress tho
L
#974
Posted 06 May 2016 - 09:10 PM
#975
Posted 07 May 2016 - 07:38 AM
Bing (2)
